Old 07-08-2018, 03:52 PM
Trooper13 Trooper13 is offline
Transmission fluid cooler needed??
Hi there,
My son rear ended someone in my '88 GW and wrecked the grill, A/C condenser, transmission cooler, and radiator.
A/C didn't work anyway, so was not too worried about that. But since I had to get a new radiator anyway, I went with a heavy duty, 3 row. Takes up more room than the stock one, but fits OK.
Since I now have a larger radiator, do I even still need the extra transmission cooler? Or will running it just through the radiator do the job? I don't know if the extra cooler is stock or an add on/upgrade. I won't be towing anything if that matters.
Thanks!!
'88 GW w/reman Jasper 360
Howell EFI
Old 07-08-2018, 06:53 PM
If you're not doing hard towing the add on cooler is a waste of time.
Old 07-09-2018, 08:52 AM
Yes, factory cooler in the radiator is fine for normal driving.
Old 07-09-2018, 12:15 PM
letank's Avatar
letank letank is offline
my take on this subject is an external cooler is a must, when you see how high the temp can go with an external cooler, and how slow the transmission oil temp decrease on a 3 mile downhill after a 3 mile uphill, I am seriously thinking of bypassing the built in radiator coolant fof the straight external cooler.
http://fsjnetwork.com/forum/viewtopi...=7473&start=40
Remember that vehicules are built to sustain their reliability not further than the covered warranty.
Michel
Old 07-10-2018, 07:55 AM
An external cooler is cheap insurance to keep an old tranny happier/longer.
Way cheaper than repairing one after overheating fluid.
1994 Caprice wagon
Old 07-10-2018, 11:08 AM
Aren't they like less than $20 and they even include zip ties to mount in front of your radiator?
Old 07-10-2018, 09:04 PM
Yeah, they are pretty cheap. It's not the money. I figured it would just be one less thing that can leak if I didn't need to use that cooler.
Howell EFI
Old 07-10-2018, 10:58 PM
Everyone knows more than the manufacturer it's always been that way.
Ditch the cooler if you're not heavy towing it's as necessary as most of the other JC Whitney treasures.
Old 07-10-2018, 11:14 PM
PlasticBoob's Avatar
All Makes Combined
It depends on where you live. Down here where it regularly gets over 85*F, and pushing around 32" tires, I would definitely recommend it.
I have an 8-pass tranny cooler (with a 14" pusher fan on top of it) and a tranny temp gauge, and the cooler has made all the difference on warm days.
If you don't believe me, hook up a gauge or get an infrared thermometer and check the lines for yourself after a lot of stop-and-go or uphill freeway driving on a warm day: you'll find uncomfortably high temps, like I did.
Rob
Click for video
Old 07-13-2018, 02:59 PM
Fasts79Chief Fasts79Chief is offline
Always. Regardless of if you tow, or heavy loads, or whtever ... a trans cooler is mandatory on older vehicles in my opinion ... if you want your trans to live.
It's not a 'belt and suspenders' approach ... it's your pants.
Old 07-13-2018, 04:01 PM
i usually bypass the rad cooler and just run an aux. cooler.
Old 07-16-2018, 06:57 AM
tarriverarms's Avatar
tarriverarms tarriverarms is offline
I thought the external cooler was stock? Getting ready to replace mine as the fins are loose and flimsy. Well actually going to repair AC and since the radiator has a busted weld on the mounting bracket I am going to replace all three coolers.
Is there one anyone can suggest or recommend over the other?
Old 07-16-2018, 08:59 AM
stock on the tow package,as i recall. any of the hayden aftermarket are good.
Old 07-16-2018, 12:45 PM
mattmopar440's Avatar
Same that way engine temp doesnt effect the transmission temp and if a external breaks u have a small fluid leak and if an internal breaks your normally looking at a transmission
91' Grand Wagoneer
401/727/229, Currently:Down for Body Work
77' Wagoneer 401 Parts rig
80's J10 258/T-5/208
89' Jeep GrandWagoneer
New Project
Inferior Chevy
Old 07-19-2018, 04:50 PM
Where did you hook up your gauge sensor? Trans pan? Cooler input? cooler output?
79 Cherokee Chief Wide Track, In pieces
Old 07-20-2018, 07:00 PM
What do you mean by a gauge sensor?
Do you mean like a temp sensor for your trans? I was wondering if that is possible. Would like to know the specifics of this as well.
Old 07-20-2018, 07:30 PM
letank's Avatar
for the tf727, here it is
http://fsjnetwork.com/forum/viewtopic.php?f=7&t=7473
need to find the plug for the th400
Michel
Old 07-21-2018, 03:01 AM
All Makes Combined
I bought a B&M gauge kit, and installed it on the top (return) line close to the transmission.
The kit told me to hack the line and install a T fitting in between it, with the sensor plugging into the T. Been over a decade and it hasn't leaked yet, but it does concern me.
I think guys running oversized tires with high gearing would greatly benefit. For example, I have 32" tires with 3.07 gears.
Before I installed the cooler, I was offroading and my tranny generated so much heat that the cooling system and engine quickly overheated. So I installed a huge cooler and pusher fan to absorb the extreme heat generated from torque multiplication when going over obstacles slowly off-road (or stop-and-go traffic on hot Southern California days). Zero heat issues since.
Rob
Click for video
Old 07-21-2018, 06:55 PM
Does anyone by chance know the cooler line hose size?
Old 07-21-2018, 11:32 PM
3/8"
It appearsI had an extra radiator.. Powersteering cooler, transmission ??? Thoughts? JP General FSJ Tech 2 07-30-2013 08:13 PM
Which ATF fuild??? Hill Billy Deluxe General FSJ Tech 9 04-05-2012 08:31 PM
Transmission Cooler Leak WagoneerinWi General FSJ Tech 5 03-18-2012 10:24 AM
Transmission Fluid Leak Mrhammer General FSJ Tech 6 08-19-2009 09:00 PM
Quick question: transmission fluid Javo-J10 General FSJ Tech 2 08-08-2009 08:49 PM
