On Jeeps, rust is most likely to show up anywhere there's steel.
OK, I'm done being a tool.
Check the frame around the spring hangars for the rear springs. Check the seams in the sides of the bed, and the fender flares. On the cab, check the floors, rockers and cab corners. Pop the hood and look at the inner fenders.
These are some of the places that rust tends to start first.
-Frank '63 J200 2WD '63 J200 4WD: J20 Axles, extended wheelbase, factory stakebed '63 J100 Panel Delivery '91 Grand Wagoneer Final Edition "If you're going to laugh about it someday, you might as well start now".
My rear, rear spring hanger let go on the driver's side. When I went to fix it I saw my front hanger and the rear spring was about ready to go as well.
Also, check the frame around the gas tank.
Cab corners, rocker panels, and the floor boards in the seam where the flat floor starts to rise near the firewall.
X2
FSJ-Earl
