So, I've done 2 AW4 swaps before and both were without the TCU (just paddle shifts).
This time here is the setup:
1990 Waggie
360 w/TBI (GM ECM xxx7747 incl. spark and fuel w/HEI conversion)
AW4
NP219 full time (my favourite)
This time I want to wire up the AW4 to be completely factory (use the TPS, TCU, shifter on console etc).
My only question is this - how does the TPS on the GM TBI compare to the 4.0 TPS ? are they the same voltage ranges ? is the travel the same ?
Reference voltages ?
If they are incompatible then I can piggyback the 4.0 TPS on the same swivel / pivot the regular GM TPS is on.
ideas ?
1990 Waggie
AW4
ideas ?
