I bought a set of matching camshaft and distributor gears from Bulltear about 10 years ago. Only driven about 5,000 miles on it, with periods of sitting. Anyway, replacing my camshaft and noticed this. Does not look good. Any guess as to what the problem could be? The distributor gear actually looks pretty good, just light rubbing. Prior to putting these on, I had worn out my previous distributor gear, camshaft gear looked fine. Worried about not getting enough oil or if there is some kind of camshaft play that could be causing this.
All input appreciated.
