Old 05-27-2012, 07:01 PM
mrtazwrench's Avatar
mrtazwrench mrtazwrench is offline
Pusher fan and A/C
Now that I have A/C in the J20 it runs just a bit warmer on hot days, I had the thought of putting a pusher fan in front of the condenser with a relay hooked up to the A/C clutch circuit so it operates when the clutch turns on. Has anyone tried it? Anyone think it would help?
Chad
Quote from Bubbles, on Trailer Park Boys...
"Let's see that red blue green **** sucker build one of these without duct taping it together!"
https://www.facebook.com/media/set/?...3&l=76427b95fd
88 wag
87 J20
82 J20
Parts vehicles: 4 Wags, 4 J20's, 2 J10's, 2 J4K's
Old 05-27-2012, 07:07 PM
I was also planning on doing this, curious to see what others think.
-Jon Barstow
1979 Cherokee Golden Eagle
360/TH400/D20
5" lift/33x12.5R15
Old 05-27-2012, 07:26 PM
asphaltrockdweller's Avatar
I have this set up on MR. Peanut.
Works pretty good!
If God is your Co-pilot, switch seats.
76 wagoneer The Muck Duck 360-4v, Ristow holley carb on Performer manifold, 160A ALT, 4" Rustys lift, 31" Cooper Discovery, slot rims.
76 wagoneer Big Bird 401-4v, 3" Rancho spring/block lift, slot rims.
74 wagoneer Mr. Peanut 360-2v, wagsag,86 GW wheels - soon to goto jeep heaven.
Old 05-28-2012, 12:57 PM
swampedge's Avatar
swampedge swampedge is offline
I run a large pusher on my condenser and it works great. I'm also running a 454 chubby.
Jim
1976 jeep Cherokee........Buick 350, turbo 400 with air, Rough Country 3" all spring and powr-loks front and rear.
You really are judged by the dogs you have!
Old 05-28-2012, 08:25 PM
Let's see you setups, mounting, fan used, wiring, controls etc. I may do it as an A/C only, or put a temp sensor on for if it happens to get hot without A/C, it did once towing before I had A/C.
Chad
88 wag
87 J20
82 J20
Old 05-28-2012, 08:35 PM
csuengr's Avatar
csuengr csuengr is offline
I put two 10" pushers in front of my condenser, wired to come on with the AC and a separate thermal switch. It worked great, even in 100+ temps sitting in traffic.
If at first you don't succeed, use a bigger hammer.
A/C to non A/C (heat only) bowtieman55 General FSJ Tech 16 06-13-2006 09:45 PM
A/C and belt question RottenDog General FSJ Tech 3 07-20-2004 02:56 PM
A/C blower is back GED General FSJ Tech 0 07-05-2004 04:16 PM
A/C retrofit. Puvong General FSJ Tech 2 05-29-2001 01:16 PM
A/C BLUES - PLEASE HELP ! ! Jordo Other 16 08-06-2000 05:32 PM
