I have been having an issue with my backup lights on my 82 j10.
They are super dim!.
I checked all the connections all the way to the transmission plug.
What I found is that circut had only 9.8 volts, so I dug some more and found that this circut also has my choke on it.i traced the wires all the way into the cab thru the bulkhead connector. Still only 9.8v.
So for some reason I had started the truck and walk!
14.00 volts at the rev lights and choke s circut.
How can I have 9.8 when the truck is off and 14 when running?
BTW the batt voltage was 12.60 and all the other things in the truck are fine
