Old 08-27-2012, 08:54 AM
barlowchiro barlowchiro is offline
Thermostat Housing ?
Ok, so while I am doing my new raditor, thermostat, etc... I figured why not spend the $10 and replace the thermostat housing. Is this also called a Water Outler??
What are the three holes for? I know one is the bypass hose to the water pump, the threads in the back are for the sensor I am guessing, but what is the little outlet on the front for?
Sorry for dumb questions but not at home and can't run out and look at it!
1988 GW
Old 08-27-2012, 08:58 AM
srobertsfsj's Avatar
srobertsfsj srobertsfsj is offline
Where are you getting this picture from? It's probably just a generic pic.
Scott R.
'86 Grand Wagoneer Super Chief 360 / TBI / WT conversion / 35x12.5x16 BFG Mud-Terrains (Project Link)
Old 08-27-2012, 09:02 AM
Advance Auto Parts, but Autozone, 4wd.com, and all others have the same picture for that part (different colors). Bjs shows the same part.
1988 GW
Old 08-27-2012, 09:09 AM
serehill serehill is offline
Gone,Never Forgotten.
yep
Just plug the hole if you don't have polution equipment. It is a thermal valve for controlling vacum
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 08-27-2012, 10:16 AM
What do you plug it with?
I am planning on removing the air pump, associated hoses, etc...
1988 GW
Old 08-27-2012, 10:24 AM
austinaubinoe's Avatar
None of the holes have to do with the air pump. Vac lines connect to this
The other one is for the U shaped water pump bypass. You need that.
I have a question too, is the OEM housing aluminum or cast iron? Mine is aluminum, but can only find cast replacements. Not hard to make an old one look nice though, as long as its not cracked or too pitted.
Old 08-27-2012, 10:35 AM
mathman's Avatar
mathman mathman is offline
I'm not too sure, is this one too pitted to use?
David
'78 J-10; '78 J-20 8400GVW
'79 Cherokee
'50 Willys (not Willy's) 4WD Pickup
Old 08-27-2012, 10:39 AM
Julep4000's Avatar
Julep4000 Julep4000 is offline
Daaang. I'm going to have to look into this further. Mine was plugged up when I got it. When I replaced everything, I followed suit and plugged it up...
'72 J4800
360/TH400/D20
Old 08-27-2012, 10:41 AM
well its a bypass, so im thinking it only becomes critical with something blocks the normal flow of things
Old 08-27-2012, 10:47 AM
Julep4000's Avatar
The more I think about it... There was a bypass hose going from the hole in the front to the water pump. The thing I plugged up was the threaded hole in the back. The picture you posted for the vac lines looks like that thing could get threaded into that hole. Mine being a '72, my guess is that the original thermostat didn't have that hole...
'72 J4800
360/TH400/D20
Old 08-27-2012, 10:52 AM
Rich88's Avatar
Rich88 Rich88 is offline
Wait a minute....
If your old t'stat housing "3rd" hole did not contain a vacuum CTO, then you do not have the vacuum lines connected to it, (since its not there). And if you're not configured correctly and need to pass emissions you may have a problem. And absence of the vacuum lines may also give you drivability problems. Is this waggy new to you (and something the PO did?) or do you not have to pass emissions testing?
Old 08-27-2012, 10:56 AM
My original one is aluminum too.
Does that vac thing go into the very rear of the housing?
What goes into the little port just in front of/below the bypass hose?
1988 GW
Old 08-27-2012, 11:10 AM
Rich88's Avatar
If you look into the hole and see threads, that's where the CTO (vacuum thing) screws in.
Old 08-27-2012, 11:12 AM
http://www.ebay.com/itm/Jeep-Grand-W...#ht_842wt_1397
Probably just a 1/4" npt plug.
Old 08-27-2012, 11:24 AM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
Should be 3/8 NPT hole, When plugging them I usually use a brass female hex plug, but whatever is handy will pretty much do.
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 08-27-2012, 11:40 AM
Ok, there are 3 holes.
The threaded one in the back is for the CTO, the big one in the middle is for the bypass hose, but what is the little one in the front for?
1988 GW
Old 08-27-2012, 11:41 AM
no the big middle one is for the main upper rad hose!
Old 08-27-2012, 11:43 AM
That's right, one of the drawbacks to not being there and seeing it.
Got it figured out now!!!
Thanks!!!
By the way where do you get a new CTO vacuum thing?
1988 GW
Old 08-29-2012, 12:07 PM
mdill's Avatar
There are 4 holes,
1) Little bypass in front
2) Big hole for Upper radiator
3) threaded CTO in back
4) Big hole in bottom for the thermstat.
Old 08-29-2012, 12:31 PM
Unbeleivable
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
No sealant on thermostat housing?? the original Honcho General FSJ Tech 15 05-24-2012 12:00 AM
thermostat housing leak flying_squirrel General FSJ Tech 9 12-18-2010 09:59 AM
Thermostat housing BURT General FSJ Tech 8 09-30-2008 09:00 AM
thermostat housing/ vac lines Jeephopper General FSJ Tech 1 05-17-2004 12:52 PM
Thermostat housing setup? Jeephopper General FSJ Tech 0 05-05-2004 10:40 AM
