Old 04-28-2010, 07:55 AM
stumpjumper3's Avatar
stumpjumper3 stumpjumper3 is offline
Riddle me this (brake question)
I know that in order for powerboost brakes to work, my engine must supply adequate vacuum for maximum braking. Well after my cam install (K8600) my brakes suck when coming to a stop, but work fine if i've got some RPM's. Could this be that my camshaft has robbed me of some of my vacuum thats required for my brakes. How could i remedy this?
Thanks,
1978 Cherokee, 4 in and 33s
Old 04-28-2010, 10:17 AM
The Colonel's Avatar
Do a search for Hydro-assist.
Before that I would check you entire vacuum system for leaks and be sure the check valve to the booster is holding vacuum.
Old 04-28-2010, 11:07 AM
Chris P.'s Avatar
Chris P. Chris P. is offline
How much vacuum are you getting at idle? I have the 8600 and don't have any brake problems.
79 J10 Honcho 360/T-18/D20
Summit 8600 cam, GM TBI
78 Wagoneer 360/TH400/QT
Old 04-28-2010, 11:12 AM
87Gray's Avatar
87Gray 87Gray is offline
Is the idle speed high enough? More rpms mean lower vacuum, but too low rpms can do the same thing.
D60 Rear Disk Brake rotor question. J20FarmTruck General FSJ Tech 2 05-15-2007 02:45 PM
Brake Drum Brand Question utvolsfan General FSJ Tech 3 11-28-2006 12:09 PM
YEEHAW! IT LIVES! And a brake question rampagefsj Off-Road FSJ Tech 8 03-26-2006 09:55 AM
Brake light question... illegalFSJ General FSJ Tech 3 11-06-2003 06:18 PM
'69 wagoneer brake sensor question Slingshot formally slingluff General FSJ Tech 8 03-14-2003 12:48 PM
