I'm dealing with a 77 Cherokee, 360 w/HEI, Holley 4bbl carb. It runs pretty good, occasional smoke on start up. In the warmer weather, it pings under moderate load-- say 35-40 mph with the A/C on going up a small incline.
The distributor is a no name HEI that was on the jeep when I got it. No EGR on the Edelbrock manifold. It also runs warmer than I think it should, ~220 on a mild spring day w/ no a/c on, ~230 with A/C on.
I have the initial timing at 10*, and using a dial back timing light, I get the following results:
Results @ 600 rpm = 10-12* degrees of advance with vacuum advance disconnected. (same with connected)
@1500 rpm = 28 -30* centrifugal advance only
@1800 rpm = 48-50 with vacuum advance and centrifugal combined.
How does the timing look? Do you think I am dealing with a timing or fuel issue? (Carb is clean, I've tried larger jets, plugs are showing white insulators as if they are lean/too hot.)
