Old 08-17-2019, 06:35 AM
Heater Blower Motor
No power to the blower motor switch in my 1986 J20
All fuses good, any ideas?
Old 08-17-2019, 07:17 AM
There is a relay buried in circuit on '86-up could be culprit?
oljeep.com has wiring diagrams if needed
Old 08-17-2019, 07:22 AM
I found one relay under the switch in easy reach and swapped a good one I had here and no power.
Not sure if that was the correct one it was the low hanging fruit I had easy access to
I will look for others under the dash
Old 08-17-2019, 07:29 AM
That relay looks like the correct one based on wire colors and there is no power to that relay
Is there a fusible link wire in that circuit?
Old 08-19-2019, 10:31 AM
It would be on the wiring diagram. http://oljeep.com/gw/elec/86/86_FSJ_...ramPage3-3.gif
Looks like a thermal fuse on the resistor stack. Seems more likely. Use your multimeter to test. Don't flail, read the diagram and measure.
Old 08-28-2019, 06:05 AM
It was the fuse on the thermal relay. I fixed it yesterday.
Thank you for the replies.
Heater blower resistor keeps burning out GrendelGrey General FSJ Tech 2 11-20-2012 11:01 AM
Heater Blower Motor Resistor - Crimp or solder new thermal fuse? 87 Money Pit General FSJ Tech 3 01-26-2012 10:18 PM
Dead Heater blower, burnt wiring spyderkeeper General FSJ Tech 3 04-25-2010 08:15 PM
Heater Blower Motor Noise cajunKen General FSJ Tech 16 12-19-2008 11:02 PM
heater blower motor harness Antelope General FSJ Tech 4 05-21-2002 02:51 AM
