My 74' Cherokee is making a noise that ain't right, Help me diagnose?
74' Cherokee - 258 - T-18 - Dana 20
If your in neutral and you hold the clutch in it's fine, when you let the clutch out it growls.
Seems like if the throw-out bearing was bad it would be quiet when released but growl when engaged with the pressure plate.....right? Or do I have it backwards?
I assume it's either the throw-out bearing or bearing on the input shaft which I hope it isn't.
I would appreciate any thoughts from experts or even someone who stayed at a Holiday Inn express last night.
