Old 09-25-2022, 06:01 AM
Cliff's Avatar
Cliff Cliff is offline
Backup Fuse Blows Immediately
77 Cherokee, 401/QT, 100k miles
Like most of our beloved FSJ's mine has experienced some wiring hacks from PO's. Most were easy to fix but one problem persists that I cannot make sense of.
The fuse for the backup lights blows when the ignition is turned on. Even before I can turn on the head/tail lights or place it in reverse. I have examined the harness at the rear and it all appears to be untouched and clean, all connections intact. Bulbs and sockets are clean and rust free. I just can't figure how ignition voltage can blow a fuse when the circuit isn't even yet energized?
Any ideas?
Cliff Danley
1977 Cherokee S
Old 09-25-2022, 06:48 AM
sounds like the switch is shorted ground or the wiring to the switch is shorted to ground.
Old 09-25-2022, 08:25 AM
nograin's Avatar
nograin nograin is offline
We will have to look at a '77 diagram to confirm, but the reverse lights are probably fed from the 'accessory' terminal on the ignition switch.
The feed to the fuse box is probably fine.
From the fuse box, the circuit with the reverse lights goes to the reverse switch. Since it happens in neutral, its probably a short in that wire.
If it was grounded after the switch, then there is no connection in neutral.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 09-26-2022, 06:19 PM
Cliff's Avatar
When you say "reverse switch" are you referring to the neutral safety switch, or is there another reverse switch?
Cliff Danley
1977 Cherokee S
Old 09-27-2022, 06:38 AM
nograin's Avatar
Off the top of my head I don't know if its seperate on your truck.
With the later torqueflite automatic transmissions, the reverse light switch and the neutral safety are combined. The backup light switch gets two wires (one always hot with key on) and the NSS has its own wire.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Old 10-18-2022, 08:04 AM
QT equipped trucks had the reverse switch as part of the neutral safety switch. It's on top of the steering column under the dash. I would start there.
Added new ground, now blows park/tail lamp fuse ZackN920 General FSJ Tech 18 08-06-2017 09:19 AM
Fixes for a broken fuse block pin firedog General FSJ Tech 13 12-29-2015 09:26 PM
Fuse box 8man General FSJ Tech 5 09-27-2015 08:31 PM
choosing the right cable and fuse sportsidedan General FSJ Tech 0 02-03-2008 04:26 AM
ACC LPS fuse blowing. roadgrime General FSJ Tech 3 12-19-2004 12:59 PM
