Old 06-03-2007, 07:09 AM
grand_wag_85's Avatar
Murphy's Law Poster Child
Backfiring thru the carb
For whatever reason my J10 keeps backfiring thru the carb. It's got a 258 and had a cam installed not too long ago. I loosened up the dizzy and spun that arround a bit while running to cut down on the backfiring, then I set it to the correct firing order and it's ALOT better but still backfiring thru the carb at high RPM's and when revved.
According to my Chilton's manual it's got the Holley 4350 carb that's supposed to go on a 401 Probably a typo...
Vacuum advance is working fine, all vac ports on the carb look good. What am I missing?
'65 J2000
Old 06-03-2007, 07:46 AM
through the carb's usually a lean condition.
Old 06-03-2007, 08:00 AM
Gotcha, tried adjusting the screws but that didn't seem to help either...There's alot of black, wet sooty stuff out of the exhaust.
'65 J2000
Old 06-03-2007, 08:25 AM
hmm. well,it can be be other issues as well.
however-the screws are for idle mixture only,popping through the carb is usually from incorrect jetting,or a faulty enrichment system,as it pops when you get on the throttle.
Old 06-03-2007, 08:33 AM
Gotcha...So how would one go about checking/determining the proper jetting?
'65 J2000
Old 06-03-2007, 08:39 AM
the jetting should be fine,since it's a stock setup.
you'llo be looking for problems in the carb.you have the bbd carb?
could be ignition,but ignition problems are usually backfiring through the exhaust.
Old 06-03-2007, 08:47 AM
<ramble>
A 4350 is a big honkin spread bore carb for 401 and 360. The big Lincolns of the era ran them on 460s too. So, you don't have that. If I ever put a 4 bbl on a 258 it sure wouldn't be a 4350. I had an 81 J10 set up like yours once. After I had it several months, it gave me fits with fuel delivery and back firing through the carb. Forget what type the early 80s 258 carburators are, but I rebuilt it first, reset the timing and it got better, but there were more problems like poor idle and rough at low rpm. It finally left me stranded on the beach in the fog hunting for 3 lost golden retrievers. I was so miffed, I just ripped all the vacuum hoses off except for the dizzy to carb connection, plugged some ports and disabled all the emissions. It ran great for the next several years. A friend of mine that worked for Chevron out on the island brought the dogs home the next day.
</ramble>
Old 06-03-2007, 09:15 AM
'82 would have the carter bbd.
Old 06-03-2007, 10:03 AM
Chilton typo Kinda figured they had it wrong anyways
'65 J2000
Old 06-03-2007, 05:06 PM
gsmikie's Avatar
gsmikie gsmikie is offline
Auto Trannie God
crossed plug wires/dist cap / flat cam/fouled plug
Old 06-03-2007, 07:36 PM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
popping is one thing, backfiring is another. Back firing is due to having timing incorrect (plug wire one off on the dizzy, timing set wrong, jumped timing chain, etc.) as the plug fires while the intake valve is still slightly open, thus allowing the explosion to continue up the intake runners and through the carb. Are you sure it was backfiring, or did you hear a sound and assume it was?
BJ's Off-Road
ryan@bjsoffroad.com
Old 06-03-2007, 08:08 PM
Well it pops BADLY at high RPM's or when revving, w/o the air cleaner on you can see puffs of smoke or vapor out of the carb.
'65 J2000
Old 06-03-2007, 08:11 PM
unclethumbtack's Avatar
unclethumbtack unclethumbtack is offline
I agree with billyrb could me a stuck valve.
Unclethumbtack
81' Cherokee the turdburglar (off-road project)
360 727 208 SOA 35" procomps
Ramsey Winch
77 J-10 258 QT (the restoration project)
Old 06-03-2007, 08:31 PM
83CherokeeProject's Avatar
83CherokeeProject 83CherokeeProject is offline
Has it been happening only since the cam was installed or did it happen before? Wondering if you are off a tooth on the timing.
Old 06-03-2007, 08:39 PM
I bought a 79 ford 4x4 with a 302 a couple of weeks a go. It had jumped time. anytime I could get it to fire it would fire back through the carb.
Unclethumbtack
Ramsey Winch
Old 06-03-2007, 08:51 PM
The condition will worsen when the engine is revved up since the timing curve kicks in with the vacuum advance.
Old 06-03-2007, 09:28 PM
The cam was installed just before I got it back in like '05 or early '06 I want to say and the problem has only started within the last few months.
'65 J2000
Old 06-04-2007, 06:08 AM
billyrb's Avatar
BJ's Off-Road
what is your current timing set at?
BJ's Off-Road
ryan@bjsoffroad.com
