Old 10-19-2019, 09:08 PM
NBD925 NBD925 is offline
J-10 258 Engine Bay rubber
Does anyone know where to get the rubber strips that keep mud and debris out of the engine bay? I
1977 Jeep J10
258 Engine
Weber 38 carb
T15 Trans
Dana 20 with Tera Low
Dana 44 Front and Rear axles
Custom 16 inch rims 235x85 R16 Duratrac tires
Old 10-20-2019, 09:20 PM
Full Size Jeeper's Avatar
A few of us have made them. I bought some reinforced rubber gasket material and cut my own.I don,t think anyone is making them. Good luck.
1978 Wagoneer
Mods:
Old 10-20-2019, 09:22 PM
1978 Wagoneer
Mods:
Old 10-20-2019, 09:27 PM
1978 Wagoneer
Mods:
Old 10-20-2019, 09:30 PM
1978 Wagoneer
Mods:
Old 10-20-2019, 09:31 PM
1978 Wagoneer
Mods:
Old 10-20-2019, 10:08 PM
Wow that looks great! Nice work. Is that attachment method based on how the original rubber was attached? If so I need to look for those attachment holes.
I don’t have any of the original material to make patterns, does anyone have pictures of a 258 engine bay or have pictures of the patterns.
It’s funny these parts don’t show up in the parts books. At least I haven’t seen them.
1977 Jeep J10
258 Engine
Weber 38 carb
T15 Trans
Old 10-21-2019, 07:57 AM
Sorry, I do not have a pattern. And I tossed out the old ones. Kaiserjeeps may have a pattern, might private message him. Yes used the same hole location, just drilled them a little bigger for the wire I had.
1978 Wagoneer
Mods:
Old 10-21-2019, 08:09 AM
Here is the jig I made to make my stainless staples. Most of my ideas were stolen from other members on this site (mostly Kaiserjeeps build thread), anyway good luck with your build.
1978 Wagoneer
Mods:
Old 10-21-2019, 08:10 AM
1978 Wagoneer
Mods:
Old 10-21-2019, 08:11 AM
1978 Wagoneer
Mods:
Old 10-21-2019, 11:06 PM
ZackN920's Avatar
ZackN920 ZackN920 is offline
Very nice looking work Full Size Jeeper.
So, are these just between the inner fender and the outer fender? Cause that's how it looks... On my 90', they appear to be glued in, not stapled(?) in.
Is anything on these jeeps supposed to go in between the inner fender and the frame rail? I got at least a 2" gap between the 2 and can see the engine when looking in the wheel well. No other vehicle I have is set up like that, they have more material keeping the engine bay and the wheel well separate.
Same deal with the rear's as well, gap between frame and body just wide open for road gunk to end up.
...not too rusty anymore
Plenty of patina
The others
1926 Dodge Brothers Business Sedan 212 I4-CRANK START
1987 Lincoln Town Car Signature Series-5.0 AOD (WD)
1987 Dodge Dakota LE 3.9, A999, 3.90 gear (DD)
1994 GMC 'Burban 5.7, 4L60E, NP241, 3.42 gear (DD)
2001 Jeep Cherokee 4.0, AW4, NP231, 3.73 (limbo)
Old 10-22-2019, 11:55 AM
On my 78 wagoneer, it had one piece of rubber on the drivers side, nothing on passenger side.
1978 Wagoneer
Mods:
Diagnose engine problems using starter Perfex General FSJ Tech 0 04-14-2010 03:51 AM
258 Engine code? brad_fsj10 General FSJ Tech 5 04-02-2004 05:59 AM
258 engine hesitation--Help wanted! Petej8 General FSJ Tech 15 11-13-2003 03:02 PM
258 engine swap n8sjh General FSJ Tech 2 02-02-2003 02:55 PM
