Old 10-16-2019, 05:47 AM
patspickup patspickup is offline
AC compressor
The Sanden compressor in my 82 Cherokee is screaming and I want to replace both the clutch and compressor. I intend to upgrade to r134 and replace a bad hose and dryer. I intend to do the installation and bring it to a shop to do the recharge. Would it be ok to drive without a charge in the new compressor? I’ve never really messed with AC systems.
Old 10-16-2019, 10:45 AM
'89_Wagon '89_Wagon is offline
I think your post got lopped off.
I went through the process of replacing the entire AC system this year. Learned a few things the hard way. Hopefully I can help.
Old 10-18-2019, 10:32 AM
Chevelleguy's Avatar
Yes, you can drive it with no refrigerant in it. Just turn the a/c off.
Old 10-18-2019, 10:43 AM
Yep, just to be extra safe, unplug the low pressure switch. On mine, it's in the engine bay-passenger side.
AC Compressor Not Disengaging After Sanden Swap supradrifter General FSJ Tech 16 08-10-2017 04:24 PM
AC compressor to air compressor...? Jeepin'WNC Off-Road FSJ Tech 4 01-14-2015 05:30 AM
Stock Jeep AC mated to a GM compressor 8man General FSJ Tech 5 10-17-2012 02:27 PM
Replace York with Sanden AC Compressor? Beach_Dude General FSJ Discussion 7 06-20-2011 08:52 AM
AC compressor Problem bigblack'74 General FSJ Tech 5 06-28-2009 01:54 PM
