Old 10-10-2019, 07:45 PM
Rusty76 Rusty76 is offline
Intake Manifold tight end bolts.
Today I installed the valley pan gasket and tightened down the manifold.
After I managed to get all bolts hand tight I started to tighten from the middle and crossing over as I worked my way to the ends. Once I got to the end bolts which are into the block it was way to hard to screw 2 of them down. I was way over spec and stopped. Currently they sit a little proud and the washer spins freely.
Need another full turn. What to do? Leave them, tap holes, pull out the cheater bar and get it done? Thanks!
image1 by , on Flickr
Old 10-11-2019, 02:37 AM
run a tap thru and try. or get shorter bolts. do not force them in you will crack something or break em off.
Old 10-11-2019, 08:19 AM
Did you verify length was correct on replacement bolts?
Agree with Ristow do NOT ever force bolts.
Old 10-11-2019, 05:53 PM
Total tunnel vision. Didn't even think about smaller bolt. I did think to maybe stack a couple washers? Anyway I picked up smaller bolt and should work thanks!
Also something I forgot to do. A guy should probably put anti seize on these bolt?
Also I've read about people putting a little rtv on the bolt to prevent fliuds from leaking. What do you think?
Thanks. HAve a nice weekend.
Old 10-13-2019, 07:54 AM
blind holes,nothing to leak thru. anti seize is fine.
Old 10-13-2019, 06:52 PM
Perfect thanks. I will take one out at a time and give her a little anti seize.
oil coming out intake bolts jlewis General FSJ Tech 9 07-24-2013 07:57 PM
Intake Manifold Replacement CommanderChaos General FSJ Tech 10 08-15-2012 11:00 AM
Decked blocks,Shaved heads,and the effects on intake manifold alignment. Ristow General FSJ Tech 18 08-04-2012 07:48 AM
Bolt holes won't line up on intake manifold. Scruffy General FSJ Tech 13 08-06-2001 03:45 AM
