Old 10-10-2019, 06:54 PM
fsj454 fsj454 is offline
Long time member
Torque
Any body now the torque on the hub spindle 6 nuts TY
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Old 10-10-2019, 07:43 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
I don't see anything specific about those bolts in the TSM. You're talking about the 6 nuts that hold the spindle over studs to the knuckle, right?
In the TSM it just says "Install spindle" then moves to the next step, no mention of a torque spec there or in the chart later. Unless I am missing it somewhere.
Old 10-11-2019, 03:18 AM
Long time member
Yes the 6 nuts that hold spindle on . I am at 55 pounds right now . 1990 GW
Old 10-11-2019, 03:06 PM
They are 3/8" studs I think, 55 is on the tight side but leave it there, you already stretched the studs out.
Old 10-11-2019, 03:19 PM
Long time member
THE TORQUE IS 45 POUNDS .TY
Bolts and their torque questions 8man General FSJ Tech 1 08-17-2013 12:30 PM
Please Help with 304 to 360 Swap Torque Converter Problem stidham13 General FSJ Tech 7 03-28-2011 10:13 PM
Ring gear bolt tourque j20brett Off-Road FSJ Tech 24 03-10-2009 09:43 AM
Torque vs Horsepower Greg Morgan General FSJ Discussion 46 09-16-2007 12:30 PM
Long Drawn-out Torque Converter Question Quartermaster General FSJ Tech 3 09-25-2003 11:04 AM
