Old 10-09-2019, 05:55 PM
Rusty76 Rusty76 is offline
Oil Pump rebuild question
Hi Everybody:
I'm about to build and install my oil pump into my 360 which is on a stand.
Just wanted to double check a few things. From what I gather packing it with petroleum jelly is past practice and I should be ok globing assembly lube on the gears. Correct? The instructions from Melling say to swirl the bits in clean oil before instal.
Thanks for the help. I really need to update my build thread. The good and the bad!
Take Care
Old 10-09-2019, 07:24 PM
Mikel's Avatar
Mikel Mikel is offline
I just oil them during assembly and prior to start-up, I spin the pump with a drill to pre-lube the whole system.
1969 M715 6x6
1963 J300 Swivel frame
I've never packed one with anything.
I simply primed it via homemade priming tool.
Old 10-09-2019, 07:51 PM
'89_Wagon '89_Wagon is offline
Just did this last night... I wiped oil on them, packed with Vaseline, and filled the oil filter with oil. It did take a few seconds to prime though.
Old 10-09-2019, 10:10 PM
NO VASELINE! assembly lube or oil. what do you think all that petroleum jelly does to the flow thru the oil filter?
Old 10-10-2019, 04:36 AM
Here in AZ it melts right away and blends into the oil, I have done this and verified oil flow to the rockers and gauge before starting.
Old 10-10-2019, 06:24 AM
or the flow is going thru the filter bypass until it dissolves. there is no way that crap is pushing thru a filter at room temp. and of all the stuff out there to use-stuff meant to be a engine lube,i kinda chuckle at it.
i aint saying it causes instant failure. just saying its really dumb.
but in all seriousness do not use valve grinding past to prime an oil pump.
Old 10-10-2019, 11:25 AM
oops. Well, live and learn.
Old 10-10-2019, 07:34 PM
Well thank you very much. Typically with my first build every move I make requires me to read the TSM, forums, Haynes and eventually it leads to paralysis by analysis!
Awhile back I purchased the oil pump mid plate and priming tool. I avoided the vaseline and went with a little oil on the gears. My engine stand is not moving so I had to build it from the bottom. Used a little of the High tack gasket stuff to keep everything is place. Torque to spec and wait and see I guess!
Thanks
Old 10-11-2019, 03:14 PM
Vasoline is not bad to use on a fresh motor as a priming help before you prime with a drill, it will help prime quicker and the melting point is very low. You can use nothing and prime with a drill, it will just take longer. The Vasoline will push through the filter with pressure as it mixes with the oil. Do what you want and feel good with, just prime before starting.
Old 10-11-2019, 05:55 PM
Interesting I actually never really though about why the vaseline.
I will for sure prime up before firing.
Thanks
Old 10-21-2019, 10:58 AM
gophman's Avatar
gophman gophman is offline
If you spin the pump with your fingers and can't feel it sucking with your fingers over the ports your tolerances are a bit loose.
power steering pump & belt question roundss General FSJ Tech 3 02-09-2011 10:41 AM
TF 727 Rebuild Video & question leostevo General FSJ Tech 2 01-22-2011 11:53 PM
Has anyone ever installed an in-line fuel pump? ultimatejb General FSJ Tech 4 08-20-2008 06:56 AM
Power steering pump rebuild gte901m General FSJ Tech 4 10-20-2007 08:52 PM
Fuel pump & speedo cable 88' Grand Wagoneer Question BrianAg95 General FSJ Discussion 2 03-27-2007 10:43 AM
