Old 10-08-2019, 08:58 PM
brentwood brentwood is offline
How to rear shackle flip 72 j4000?
I ordered a pair of 4in front lift springs from alcan. And would like to do a shackle flip in rear.
How do you do a rear shackle flip on a 72 j4000?
Any special parts needed?
1982 Wagoneer w/258, Rusty's 4in spring lift, motorcraft 2100, 32x11.5x15 bfg's *sold*
1972 J4000 Chevy 350, th350, divorced Dana 20, Holley carb, alcan 4in springs, 35in BFGs on 15in slots
1978 J10 golden eagle w/Levis interior, 401and th400, Edelbrock avs2, 32x11.5 falken rubitreks on stock golden eagle wheels
Old 10-08-2019, 10:35 PM
Kaiserjeeps's Avatar
I would do it with a correct set of springs. Or spring and lift block combo. The shackle flip is not a good idea for two reasons. One is with enough articulation the shackle can flip back up to it's factory position and next thing you know is one side of your truck will be squatting needing to be set back to how you had it. Second is it will raise your pinion completely taking your U-joints out of phase. By 8 plus degrees actually. That will make a terrible vibration. I just went through all this with the 70 wagoneer in my build thread. I have not updated my posts to reflect my incorrect assembly of hanging the rear shackle under the pin. I was 8.3 degrees out. I fixed it and now I am inside 1 degree out.
Hell creek is the only company that makes a lift for the J trucks if I remember correctly. They are expensive but you get it right the first time. Maybe BJ's sells a lift kit too. I am not sure.
Anyway, my 1.5 cents worth.
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
71 project J truck FOR SALE
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's
Old 10-09-2019, 04:27 PM
Better to leave the lift blocks that came on truck than rear shackle flip?
Old 10-10-2019, 12:19 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
Lift kits come with lift blocks instead of shackle flips for a reason. Often times a shackle flip isn't possible at all, but in the cases where it is, it's not the stablest option. OEMs don't tend to run that way either, for that reason.
If you can avoid the flip, that would be the safer bet.
Old 10-10-2019, 05:13 PM
Understood, thanks.
I'll leave the blocks while I save up for rear springs.
Old 10-11-2019, 11:01 PM
44BZ's Avatar
44BZ 44BZ is offline
My 68 J2000 has the rear shackles flipped down. I've had no issues with vibrations, binding, or flipping back at all. Been that way since I bought it, 9 years ago. I don't see the problem.
Rear Shackle flip and Front lift undecided temps425 Off-Road FSJ Tech 16 03-17-2014 10:51 AM
BJ's Rear Shackle Flip Help Woody the Danger Wagon Off-Road FSJ Tech 14 10-29-2009 09:34 AM
4" SOA with rear shackle flip jeeprunner81 General FSJ Tech 9 06-30-2007 02:04 PM
post mount shackle flip "72" j350 Off-Road FSJ Tech 9 09-28-2006 09:18 PM
