Old 05-10-2019, 04:53 PM
1990 Grand 1990 Grand is offline
1990 GW EGR Valve Cali Smog issue
I moved to California and shipped my 1990 Grand Wagoneer with 68k miles out here. I've had Cali catalytic converter, new carb, etc. replaced to pass Cali Smog but mechanic now says EGR valve is bad. That valve is discontinued and is different than most EGR valves because it has 2 nipples, one on top and one on bottom. It's # 5300 6332. I've looked everywhere and am out of options. Any ideas on where to find one?
Old 05-10-2019, 05:18 PM
I am unaware of anyone who makes that EGR any longer.
CA ARB website has a phone# for parts locating assistance.
I was unable to locate a replacement so just swapped on an older style.
However my 90 has passed CA smog several times with an older 88-down EGR valve.
Old 05-10-2019, 06:30 PM
Tripwire's Avatar
Tripwire Tripwire is offline
i also have never seen a double nipple EGR, and i have parted out 5 rigs from 86 to 90
Abort? Retry? Ignore? >
Old 05-10-2019, 06:37 PM
Do you just not use the EGR transducer? The '90 EGR valve also has a port at the base for a transducer.
Old 05-10-2019, 06:58 PM
Correct. No transducer just regular style EGR.
YMMV but it hasn't ever been any issue to pass that way.
Old 05-10-2019, 07:30 PM
kansasboy001's Avatar
kansasboy001 kansasboy001 is offline
If I understand correctly the old ones have a transducer of sorts built in. The transducer on the new ones just passes vacuum once a certain exhaust back pressure is reached. The old ones do this too just with internal springs. I think the reason for the change was that the old ones were a gm part and Chrysler didn't want to keep buying egrs from gm.
1983 Cherokee Laredo. 360/ 727/ np228/ Junkyard 7427 TBI/ Msd ignition
Old 05-13-2019, 01:15 PM
Yeah, the smog techs I have gone through, lifted my hood, poked around a little, made sure it was still a 2bbl, then dyno'ed it. You also have to pay for the evap test so make sure you are ready for that. The smog techs see so few carbs anymore, they just don't care enough to crack out the book and start verifying stuff. I have an operational late 70's/early 80's transducer I would sell you if you install an early EGR and have problems with it.
When I got mine running, I had a slight off idle stumble without the transducer. So install the early/single nipple EGR and drive it. If you notice an off idle stumble, install a transducer.
Old 05-14-2019, 01:51 PM
OK, I bought an older style EGR Valve J324 0102/EGR4471/EGV 335 but the mounting base is larger than the '90 EGR Valve that has a broken diaphragm. Does anybody know of another valve # that might work? Thanks!
Old 05-14-2019, 02:08 PM
Did you try to mount it?
The older ones are a bit bigger but bolt up the same.
Help identify which EGR valve I need sflier General FSJ Tech 7 11-08-2008 06:46 PM
Bad EGR valve? and carb tuning question. JeeperJay General FSJ Tech 3 07-12-2005 04:51 AM
EGR Valve and Anti Knock Kits(still available) Nobby General FSJ Tech 0 04-02-2003 07:37 AM
EGR Valve DerJeep General FSJ Tech 2 11-26-2000 04:32 PM
