Old 06-17-2017, 04:39 PM
Where do you stick the PCM?
I'm setting up an MS2 PCB 3.0 throttle body injection system in my '75 Wagoneer. It has the factory AC system taking up a lot of real estate inside and the computer isn't rated for underhood temps.
Where do I put this thing? pics would be helpful. So far I've come up with glove box, passenger kick panel or maybe way in the back somewhere? I don't think it quite fits under the bench...
Thanks in advance.
Old 06-18-2017, 09:54 AM
There is a LOT of room behind the dash.
If you drop the AC unit, you have a very large area to mount it.
Or you could take out the glovebox liner, or pull the cluster, and "".
If you don't care if it's visible, can also mount it to/below the AC unit.
Quadratrac Slip Stick condition dkmcgowan General FSJ Tech 12 06-17-2013 09:48 AM
D20: to Twin Stick or not to Twin Stick...that is the question scantar General FSJ Tech 20 02-04-2009 09:38 AM
Are there any Twin Stick Cable Shifter Kits SFBAYBOATER Off-Road FSJ Tech 6 01-30-2007 12:43 PM
Dip stick Tube Help M1Garandfan General FSJ Tech 4 07-28-2002 06:50 AM
Transmission Dip Stick HELP shadowfax101 General FSJ Tech 0 04-15-2002 09:55 AM
