Old 06-06-2017, 10:47 PM
skeletor's Avatar
skeletor skeletor is offline
Fitech installed with command center
Hey, I don't post a whole lot anymore, but in the last couple days I have installed a Fitech system using the command center. So far it is way better than any carb. Completely got rid of my hot start issue. It took about a day and a half and started on the third crank....here's a video:
https://m.youtube.com/watch?v=QQa2h7...m-upload_owner
-bryan
1984 j10 LWB
1977 Cherokee chief wide track(sold)
2004 LJ
Old 06-06-2017, 11:43 PM
Full Size Jeeper's Avatar
Nice set up, I would like to use this injection on mine. Do you have a ballpark figure on the cost, and where you made the purchase from?
1978 Wagoneer
Mods:
Old 06-07-2017, 08:27 AM
skeletor's Avatar
I got it about a year ago from jegs and just now got to installing it...with everything I have somewhere around 900-1000 in it. That's the basic low price it seems for any fuel injection kit...
I also have msd ignition and cs144 alt and I think that definitely improves the Fitech.
-bryan
1984 j10 LWB
2004 LJ
Old 06-13-2017, 06:21 PM
R69US's Avatar
R69US R69US is offline
It's a pretty slick system. I had some trouble with starting, but that's only because I made the (apparently common) mistake of wiring up the white wire to accy instead of a constant switched 12V signal and it was dropping off during cranking. But I agree with you...for the price it's hard to beat and way better than a carb.
Old 06-13-2017, 11:36 PM
j10jim's Avatar
j10jim j10jim is offline
My brother in law has this on his 74 J20. Loves it. Wish it was smog legal for the 75 and newer trucks
1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
1976 Cherokee Build Coryd55 General FSJ Tech 485 07-17-2014 08:43 PM
Hydraulic brakes finally installed!!! SNO*MAN General FSJ Tech 12 11-10-2011 11:16 PM
Brush Guard installed bruner1981jpce General FSJ Discussion 2 06-28-2011 07:23 AM
Installed ram assist on my FSJ BigDan Off-Road FSJ Tech 35 12-04-2006 08:31 PM
MSD 6A installed, but engine continues to run FSK1460 General FSJ Tech 7 08-24-2004 04:00 AM
