Ok y?all I?ve searched on here but can?t seem to find my exact problem, I didn?t want to start a new thread if one existed. Sorry for the long post here, but I want to make sure I give you all of the details.
Details:
1987 GW
Gas V8 360
Auto Trans
108K miles
I have owned this for about 3 weeks now and I?ve had this problem happen twice now. I drove this home to VA from NC after buying it and it drove fine. It sat for a week while I got insurance and registration done and then I went to drive it and it cranked up and I drove it from my house down the street to the first stop sign (.25 miles) and I was waiting to turn and when I stopped it cut off on me. It cranked right back up and when I put it in gear and then gas it died again. I opened the hood and checked a few things as my neighbor drove by and stopped to help. I tried to start it again and nothing and gradually it wouldn?t even crank up at all. He checked for spark when trying to start it and still nothing. We towed it back to my house and I took another car. My wife got home about an hour later and it cranked up fine and she put it in the garage. The following day it cranked up fine and I sprayed carb cleaner in it and hadn?t had a problem, it cranked up and drove fine each day.
I drove it a few days later and no problem. I got home and then I had to take it to drop it off at the mechanic to get inspection and new tires. I went out to crank it and absolutely nothing. I noticed the positive battery cable was getting hot when trying to crank it. It sat for an hour and cranked up fine, I drove it to the mechanic and told them to check it out. They replaced the positive battery cable and said it was starting fine.
This past Saturday it sat all day and on Sunday it cranked up fine and then I got to the same stop sign and it was doing the same thing. I tried a few other things and then came to realize it would crank and idle fine, but once I put it in gear it would die. I let it sit for about 30 minutes and then it cranked up fine and I drove it back to my house and parked it. I then went out and cranked it up about an hour later and drove fine all day.
So, any ideas what is causing this problem, it seems to be when it sits for a day or more and then once load it put on the engine.
Details:
1987 GW
Gas V8 360
Auto Trans
108K miles
