Old 09-10-2012, 11:41 PM
Woodchomper's Avatar
Woodchomper Woodchomper is offline
How to build a fan shroud. Dial-up beware!
Here are the steps I took to make a fiberglass fan shroud:
Step 1: Use 1" insulating foam to build the buck (form). The foam layers are hot glued to each other and to a 1/4" mdf backer board.
Step 2: Shape the buck with sandpaper:
Step 3: Notice the tilt of the foam. A wedge of foam was glued in to account for the tilt of the engine.
Step 4: Cover the edges with foil tape.
Step 5: Wrap the buck with fleece. Staple fleece to the back of the backer board.
Step 6: Apply two coats of fiberglass resin to the fleece. I used 3M fiberglass resin from Home Depot.
Step 7: Apply three layers of 3M fiberglass mat to form and sand.
Step 8: Apply a layer of body filler and sand.
Step 9: Apply Rust-oleum sandable primer/filler and sand.
Step 10: Apply more body filler and block sand.
Step 11: Remove shroud from buck, sand, fill, sand, fill, sand, fill, sand.
Step 12: Mount brackets to radiator. Notice the shroud mounting tabs on corners.
Step 13: Paint shroud with Rust-oleum hammered metal finish.
Step 14: Mount shroud to radiator.
Step 15: Optional towing option - Mount junkyard Mercedes pusher fan to front of radiator.
Step 16: Enjoy the highway cooling that can only be obtained with a mechanical fan. Previous running temps with the Ford Taurus fan were 210 degrees. Also note I'm running a .040 over 401. You know the ones that always run hot if you bore them anything over .020.
1991 GW 401 /727TF/NP229 /4" Skyjacker /EBL TBI /CS-144
1981 J10 401 /727TF/NP208 /6" Superlift /CS-144
Old 09-11-2012, 12:07 AM
mdill's Avatar
mdill mdill is offline
Looks good, It will be interesting to see how it holds up. The glass transition temp of Polyester resin is on the order of 50 degees C or ~122 Degrees F and tends to degrade with moisture.
Let us know how it does.
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 09-11-2012, 12:14 AM
Blake Blake is offline
Very nice!
GREAT Oil Pressure too!
Old 09-11-2012, 08:59 AM
j2sax's Avatar
j2sax j2sax is offline
Mdill, what would be a better material to use for making a shroud that is going to be subjected to such intense temp swings?
BTW, having seen this Rad/Fan/Shroud up close and personal, I can tell you Rich takes pride in a job well done and it shows! All looks better than factory and is obviously effective! Way to go big Rich!
Still think you and Del need to square off and see who is the Dominant 401 Waggie in the St Louis area!
Jesse- Sparta, MO (Near SPfdl MO) J20 4 Door Project, Wag w/ 6" Rusty's, 33x12.5's, 360/727 (for now!), 77 J10, 80 J20, 3 80's Wags, 73 Commando, Lots of AMC Eagles, FSJ parts Rigs and parts
Old 09-11-2012, 09:06 AM
grand_wag_85's Avatar
Murphy's Law Poster Child
That's pretty slick, thanks for posting!
'65 J2000
Old 09-11-2012, 09:20 AM
billyj7175's Avatar
Looks good Rich.
83 J-10 Jeep "Oscar"
360/727/229
Old 09-11-2012, 10:52 AM
men in black's Avatar
Nice job
Another use for action fleece
Old 09-11-2012, 11:37 AM
Mars's Avatar
Mars Mars is offline
sweeeet!
Wannabe Fabricator
Grumpy on a good day.
Old 09-11-2012, 12:26 PM
Achilles's Avatar
Achilles Achilles is offline
Nice looking Shroud>
YouTube: http://www.youtube.com/channel/UCmcfvYSDdeFJ-NHY1MA_9Iw
Old 09-11-2012, 06:22 PM
Southern Gorilla's Avatar
Southern Gorilla Southern Gorilla is offline
That is awesome.
It's not an SUV. It's an SEV: Surface Exploration Vehicle.
'76 Cherokee NT
360/T-18
Trailers belong behind trucks, not under them.
Why? Because nobody in the history of 'wheeling has ever said, "good thing I put those smaller tires on my rig."
Old 09-11-2012, 06:23 PM
81cherokee laredo's Avatar
81cherokee laredo 81cherokee laredo is offline
Nice write-up,'where do you get the fleece?
Dan
81 Cherokee Laredo- 360 727 NP219 SOA/SF 35 Coopers 4.56 Gears
83 Cherokee - Katy- long term project
89 Grand Wagoneer- 360 727 NP229 31x10.50's on slot rims
Old 09-11-2012, 07:33 PM
Ghinmi's Avatar
Ghinmi Ghinmi is offline
Super Moderator
Saw this in person this weekend! The pictures do not do it justice, Rich does some nice work. Add this to the 'future project' list.
Old 09-11-2012, 07:43 PM
j20owner's Avatar
j20owner j20owner is offline
Stuff like this needs to get posted over on the 'network' so it's not lost.
Where is my axle?
79 j20/84 GW GM Hybrid
Old 09-12-2012, 05:13 PM
jamesdart
Posts: n/a
this works good. ive made them for my hotrods, where there is no factory shroud. never used foam as a shape, just 2 pieces of masonite and streched the fleece over them to shape then resin and a few layers of fiberglass cloth. same technique as speaker enclosures.
Old 09-12-2012, 07:46 PM
mdill's Avatar
I am not up on my composite materials, so I am not sure if there is any good room temp cure resins for high temp use.
One of the reasons (the smart ones anyway) home built composite aircraft are painted white, you don't want to lose a wing taking off after sitting on the tarmac in the sun on in the south on a hot summer day.
His work looks great and I do like the idea, I am just unsure that it will hold up to real use, it might work great and last long enough in a low use application.
Old 09-12-2012, 10:26 PM
del's Avatar
del del is offline
shroud
The shroud looks good, and was needed for the aftermarket sourced radiator. You wouldn't need the shroud if you just left the hood open a little bit. (joke from last weekend) The idea of the pusher fan as additional cooling when needed is cool also. Post the year and model for everyone. That would be another good post- the fan and wiring. Looks good man...Del
1987 Wagoneer
4" BDS Springs, 31"x10.50's
401/727/229
Old 09-13-2012, 05:24 AM
Nice!
Old 09-13-2012, 07:05 AM
Thanks for all the comments. After two days, I finally just got access to this site.
The fleece came from Jo-Ann fabrics. I think I was the only guy in the store that day and it felt weird.
Del, The fan came out of a big Mercedes probably late 80s or early 90s. I really didn't pay much attention to the vehicle when I pulled the fan. I was originally looking for a BMW E35 fan (2 speed) but the ones I found had broken blades. When I saw the Mercedes Fan I just grabbed it! One other benefit of a pusher fan is air conditioning at idle. That is as soon as I get a condenser mounted and new lines for the AC.
Only time will tell how well this shroud will hold up. The shroud is actually about 1/4 inch thick and is fairly sturdy. Concerning the thermal breakdown temperature for polymer resins, I sent 3M an email and ask if they could provide me the specifications for their product. If in time the shroud deteriorates or cracks I'll come up with another solution. After all, it won't be the first time I fixed the same thing twice on this Jeep.
The building of this shroud only took about a week to make from start to finish. It wasn't that bad really, I would come home from work and put a coat of fiberglass on the shroud and call it a night. Part of the experience gained by this project will be used to make speaker enclosures for my son's 87 Wag.
One last word of caution, if you do a project like this read the Material Safety Data Sheet (MSDS) for the product you use. In the case of the 3M resin it is recommended to wear an organic respirator when applying the product and while sanding.
Old 09-13-2012, 07:20 AM
manimal's Avatar
manimal manimal is offline
That is a very nice piece of work. Great job.
-Lance
Originally Posted by REDONE
Bring some wet-naps. I'm gonna lick everything you butt doesn't touch!!!!
Heck Yeah, I am an equal opportunity offender today and think we should all get bent.
Old 09-13-2012, 07:34 AM
3nellieb's Avatar
3nellieb 3nellieb is offline
ok this looks great but a few people have said something about it not holding up. correct me if I'm wrong but weren't the factory ones on the waggies fiberglass. the last two I bought both still had them, they looked factory and I know for a fact they were fiberglass and these rigs were 20-30 years old and the shrouds were still holding up.
Stupidity is often rewarded with pain.
86 waggy fresh 360 big bore tbi and all the works fresh727/208 4:27s front locked rear spooled 4'' bjs springs and 2'' body 37s irok(as of now) lots of cuttin.
Russian Mudding Video -- Dial up beware! 2ndtimearround General FSJ Discussion 24 12-21-2011 06:51 AM
Bought another one today...dial up beware!! KaiserMan General FSJ Discussion 48 02-27-2008 07:28 AM
two update pics.....dial up beware, large pics jeepzilla47 Off-Road FSJ Tech 9 09-13-2006 05:26 PM
