Old 06-07-2004, 05:43 AM
youngjeeper's Avatar
youngjeeper youngjeeper is offline
well the leather on my steering wheel in the 88' was really worn in some places, it had gotten a hole down to the padding. on my drive home from uwharrie i noticed a new hole past the padding and it was marroon! i was curious so i made the hole bigger...then i ripped my whole steering wheel leather cover off to find a nice new steering wheel!!! its the same material as the dash pad under there and looks great..just figured id pass the tip along
88' GW Stock & Mint
77' CJ-7
http://gfsj.org/forums
Choptop/Crew Cab Build-up
http://www.ifsja.org/forums/vb/showthread.php?t=93389
Old 06-07-2004, 07:22 AM
The wheel on my J10 is worn like that. I will check further to see if it is like that,,,,,but I really really don't want a maroon steering wheel,,,,,,,
Old 06-07-2004, 05:58 PM
RWalker's Avatar
RWalker RWalker is offline
Mine is the same way. I was going to just go with a black color since I couldnt find a decent match and then when I pulled off the old cover I found that the steering wheel matches the dash and interior. No one has ever noticed that the cover has been removed.
1988 Jeep Grand Wagoneer
Old 06-08-2004, 03:11 AM
elvismith elvismith is offline
Interesting. Can one of you post a pic?
Old 06-08-2004, 10:22 AM
bob13's Avatar
bob13 bob13 is offline
Cut mine off a few weeks ago. Much better than the torn up leather look.
bob
[ June 08, 2004, 04:23 PM: Message edited by: bob13 ]
89Wagoneer SOLD to Millerluck
Old 06-08-2004, 04:25 PM
Buddy in Texarkana Buddy in Texarkana is offline
I went with the Wheelskins leather cover. It is a really high quality cover. Grandwagoneers.com has them for $60 (ouch), but you can get them straight from the company somewhat cheaper. I like the way mine turned out. Not too hard to put on either, just take your time and keep it TIGHT. The only difference is that the ones from the company direct have holes all the way around (GW's are custom with the holes left out where they need to be for a Jeep wheel). This works better, because you can rotate it just a little to offset the seams at the bottom to get a better fit. I really like mine, and have had several folks ask what kind it is so they can get one. I think their web is:
http://www.wheelskins.com/
1988 GW 136000mi (daily driver), Stock springs with a little sag, 31-10.50's on stock rims, de-smogged 360 w/ rebuilt 2150, More leaks than I can start to track down, more money than I want to add up.
Old 06-09-2004, 04:04 AM
Matthew W. Woodruff Matthew W. Woodruff is offline
Wait a sec, are you telling me that my cheap-looking plastic steering wheel was orginally covered by stanard-issue ultra-luxury leather wheel wrap?
I knew that the PO had beat on my Waggie pretty hard, but I didn't know that he had also skinned her alive ...
Buddy in Texarkana: which "works better"? the wheelskins or the grandwagoneers.com wrap?
Matthew W. Woodruff<br />woodruff@panix.com<br />1989 Grand Wagoneer \"Laredo\"<br /><br />What works: tailgate window, rear wiper/washer, power windows, A/C, temp and compass, seat belt buzzer, fog lights, cruise control<br /><br />What doesn\'t: gas gauge, remote door locks, rear window defroster, cigar lighter
Old 06-09-2004, 12:08 PM
Millerluck's Avatar
Did mine like that years ago.
After time you will get this black funk on it like mine.
Later
Larry
88GW "Mississippi" 401,Edelbrock heads,and stuff,
4" Skyjacker, BFG AT's,OBA,Air Horn.
'89GW "Mutt" wood for now, 360, 1405, Edelbrock cam,
4"Rusty's,3"body,33"BFG. Detroit Truetrack Warn Hubs
The Metal Workshop
http://www.themetalworkshop.com/index.html
