EGR should hold vacuum right?
  • bfroe
    • Apr 21, 2010
    • 140
    Sorry if this is a silly question...
    PO put a new EGR just before I bought the truck so it is still very new.
    While replacing all the vac lines, I sucked on the one connected to the EGR, and it wouldn't hold any vacuum. I could almost breath through the hose !
    Is this normal? I feel like it's yet another vacuum leak...
    Thanks!
    Ben
    87 Grand Wagoneer, 235k, 360/727/229 TFI bored .030
    http://s438.photobucket.com/albums/qq103/Jimmorrison91/
  • FallonJeeper
    • May 28, 2010
    • 433
    Sounds like the EGR or vacuum line is bad.
    • Tripwire
      • Jul 30, 2000
      • 4656
      yes and no - IIRC
      the only way to test it is while on the engine and hooded up to a engine vac source as a mityvac cant pull enough suction and the valve requires some exhaust back pressure to function
      be sure its clean and the passeges are clear, bolt it back in with the gasket and run a temp line directly to a ported vac source, rev the engine and you should be able to feel the diaphram move with engine rpms
      i learned this the hard way and spent 65 for a replacement egr i did not need
      at idle manualy depress the diaphram with your fingers and the engine should start to die
      Abort? Retry? Ignore? >
      • bfroe
        • Apr 21, 2010
        • 140
        Originally posted by Tripwire
        yes and no - IIRC
        Will do. soon as i put all the new vac lines in, thanks!
        • #5
          It is not that a hand held vacuum pump can't make enough vacuum to open the egr valve, it is that there has to be exhaust pressure to make the internal valving operate correctly. So in order to test the valve, you have to have it on a running engine.
          There are two types of valves, positive and negative. Positive valves operate this way. Negative valves can be tested with a vacuum pump and don't need to be on a running engine.
          • Tripwire
            • Jul 30, 2000
            • 4656
            thank god i was half right theres hope for me yet ! i thought it had something to do with back pressure but was not sure
            thanks for a little more enlightenment
            • smogdredd
              • Jul 19, 2010
              • 464
              Aftermarket egr warning
              Almost all aftermarket EGR valves flow too much causing a misfire at 2500 RPM under no load. This can be a problem in some states because of the way the high speed portion of the smog test is done. Always use the smallest restrictor in the package. Try to cross the OEM part number to a new Delco unit if posssible. If Youre vehicle fails due to a high HC reading at 2500 rpm this is often the cause. Unfortunatly the part suppliers are completly un-regulated and don't have to answer to anyone. Even in California.
              '63 wagoneer '87 360 running gear except T case (207), warn hubs, 3.56 diffs and EFI Holley pro-jection using ford cfi throttle body Stock dist. with four wire HEI module.
              '67 Scout 152cid w/EFI and turbo also My own a little help from Chrysler. I am a fabricator, I make stuff up!
              facebookGGAutoCare
              • smogdredd
                • Jul 19, 2010
                • 464
                Loaded mode?
                Thanks!
                Ben
                I've never done a loaded mode test on a vehicle wiyh an aftermarket EGR, The problem I metioned may not be an issue under load but if You live in a basic area it's often a problem.
                facebookGGAutoCare
