  #41
Old 10-17-2019, 05:44 PM
Originally Posted by pickledtoast
I'm not entirely confident in my initial waggy flexplate digitization. I will redo it when it all comes apart and remeasure. That said, I have about .175" difference between my '90 wagoneer flexplate starter ring gear and the ATP Z337 (XJ AW4) flexplate starter ring, with the waggy ring being further inside the bellhousing.
Again assuming it is accurate, you would need about a .275" spacer between the AW4 torque converter and the 360 flexplate, that's the method I'm planning on going with.
The bolt pattern on the AW4 torque converter is not even close to the 360 hole pattern, but the holes can be drilled.
Not sure why, but I can't see the pic. But, thanks for the info.
I might just go with balancing the aw4 flexplate like my 360.
Old 10-27-2019, 07:40 PM
The transmission cooler is falling apart so it's going to be replaced. Does anyone know the cooler width off hand? Hoping to use to OEM mounts/brackets.
UPDATE: Was able to measure...22.5" wide end to end.
Old 10-28-2019, 03:26 PM
gpcl16 gpcl16 is offline
Just curious why you want to keep your NP229 with this swap? If your AW4 came with a NV242 that would be superior transfer case in my opinion. Much more reliable torsen for the center diff instead of a VC, as well as a locked 4hi option, native bolt up to the AW4, and getting rid of the problematic vacuum shifter as well. Seems like a win win.
1988 Jeep Grand Wagoneer
4" BDS Suspension Lift
Tru-Trac Rear
Howell GM TBI with Custom Tune
Old 10-28-2019, 07:03 PM
My aw4 did not come with a transfer case. The NP229 does just fine for my needs... think family fun car with occasional snow usage. Also, converting to another transfer case seems to add more complexity to the swap, like linkage, speedometer, shifter ect. Keeping the NP229 may not be optimal, but the extra work to adapt the wagoneer to another transfer case just didn't seem worth it to me.
Old 10-29-2019, 08:01 AM
Similar reasons here for keeping the NP229. My vacuum shifter works well for now.
But...the vehicle speed signal for the TCU comes from the 242 VSS. I'm not sure yet how I will handle that. Originally I figured I'd just replace my speedometer with a not-cable driven unit, but I just fixed my cruise control and that gets it's speed signal from a speedometer cable in-line vss.
Either way I figure I will have to create a VSS, either for my cruise or for the TCU.
Old 10-29-2019, 09:17 AM
Looking into transmission coolers... I'm thinking of getting something in the 20k-26k BTU range. Is that overkill or not enough?
Old 10-29-2019, 09:23 AM
I could be wrong, but I think the VSS for the AW4 is near the output shaft of the AW4 and not the NP242. This might be different depending on the year. But, this would make sense to me based on the harness and transmission I have sitting in my garage. Technically, it's the trans output sensor.
Check out the pictures in this link.
https://www.cherokeeforum.com/f2/tra...cation-243436/
Old 11-01-2019, 09:22 AM
Overkill.
Plumb it through the radiator, for sure, and add a small cooler (think OEM sizing for a similar rig)
It's easy to go overboard here. What you want to remember is that a transmission has a designed operating temperature the same as an engine and that the lower tank of the radiator, lo and behold, is about that temperature.
Somebody chime in if they can show me wrong, but colder is not always better on a trans.
Old 11-01-2019, 06:35 PM
Originally Posted by yossarian19
Overkill.
Do you know what thread size the fitting is on the radiator?
Edit: seems like 1/8 npt... Will test. I've read the aw4 runs hot but could I just run it with the radiator cooler only? I do not plan on towing but do plan on many drives through the white mountains with camping gear which has some steep grades
Old 11-12-2019, 08:49 AM
Regarding Trans fluid temps, I bypass the radiator on all my vehicles because the engine is running at 195/210 degrees and the danger zone for a trans is 220. With a separate cooler of 24000 GVW they run at approximately 160-180 degrees and under heavy use approach 200. I dont live up north and dont need to concern myself with startup temps bellow zero but you can control the temps somewhat with a controlled aux' fan. It wouldnt turn on until after reaching a higher temp. Ive worked around hydraulics all my life and if any of it gets to hot to touch--its getting too hot.
Note: I had a 93 Ford with A4LD electronic trans and it would get hot and puke the fluid out during Off Roading. This left me stranded twice at the worst possible time. I resolved the issue by bypassing the radiator and it never did it again and the were no negative effects to running it cooler.
Old 11-13-2019, 09:30 AM
Appreciate all the advice on coolers. I've leaning towards routing it through the rad and then to an external cooler, like the OEM setup. If it didn't get so cold where I live, which it often does, routing to just an external cooler would make sense just to keep things simple and get the lowest temps.
The AW4 I bought came with a Hayden 24K GVW cooler so that's what I'm using. Maybe overkill but I'm thinking with the bottom of the radiator temp at 180, the trans fluid temp might drop to 160 by the time it exits the external cooler. Operating range for the AW4 is 125-176 so this setup seems good.
Bought more parts.... mostly fittings, lines, and clamps. Will post some pics. So far, I've spent ~$650. Big items were the transmission ($200), wiring harness ($100), and spacer ($75). All the little stuff adds up quick! I'm sure buying a parts jeep would have been less costly, but there's no way I could have one in my yard and be happily married .
Old 11-22-2019, 07:14 AM
Mikel's Avatar
Mikel Mikel is offline
For those with AW4s, other than having an overdrive, how do you like it compared to the 3 speed auto it replaced? (in terms of gear ratios, gear spacing, shift patterns, lock-up in the lower gears...)
Thanks.
1969 M715 6x6
1963 J300 Swivel frame
Old 11-23-2019, 10:04 AM
I haven't driven mine in the SJ much at all yet. In XJ vehicles with the 4.0, I've got a *ton* of miles driving them.
First gear is a bit deeper than the TH400, second is darn similar and third is the same.
Lockup in lower gears is seamless, I can't think of a time I've really noticed it.
The only obnoxious thing is that when you put it in 1-2 (first two gears are in a combined shifter position) it will wind out to like 5000 RPM before it shifts to second. There are modifications to fix this, so you can select full automatic or lock it in a specific gear. But then, how often have I wanted to lock it in second? Like... maybe once or twice, in ~12 years of driving rigs with AW4 transmissions. It's a very specific off-road-only use case where that is annoying.
Old 11-26-2019, 07:53 PM
This swap will move the transfer case 4 inches back. I read a bit about clocking axles for double cardan joints, which would apply to the front axle. Is this something that needs to be done?
Old 12-02-2019, 07:48 AM
4" eh. I'm getting no where near that with my tape measure, but you are further along than I am.
Old 12-02-2019, 07:51 AM
Honestly, I haven't confirmed that yet. I just remember reading that somewhere. What measurements did you get? I plan to start the actual swap later this week.
Old 12-02-2019, 08:07 AM
Dont try and Clock the front axle to meet the CV because it will likely make too big of a change to the Caster. The rear axle can be clocked without issue.
Old 12-02-2019, 08:53 AM
I was getting almost the same, until you pointed out we need the 7/8 spacer to reuse the NP229. So now I have 7/8" further rearward.
That's me measuring bellhousing to transfer case flange with a tape measure on the A727, not very accurate. (I digitized the aw4, it's 25.300" bellhousing to transfer case flange). But I shouldn't be 4" off.
Old 12-02-2019, 12:00 PM
I did not measure my A727, but grabbing the length from advanced adapters and Novak sites, here's what I come up with in inches for the relevant pieces. I'll tape measure as well just to confirm.
A727
Transmission Length: 22.625
Total Relevant Length: 22.625
AW4
Transmission Length: 25.375
Adapter: .875
2-Transfer case gaskets: .125 (optional?)
Total Relevant Length: 26.375
Difference = 3.75
Here's a link to advanced adapters A727 length.
https://www.advanceadapters.com/tech...rqueflite-727/
AW4 length link
http://www.novak-adapt.com/knowledge/aw4
EDIT: Measured the AW4, A727, adapter+gaskets and the values above check out.
Old 12-03-2019, 06:57 AM
Yeah you're right. I just rough tape measured my A727 at around 23", so that 22.625 value is probably right. I don't know what kinda crack I was smoking before.
Jeep sat for 2 years, now has tranny problem jpekarek General FSJ Tech 15 02-15-2011 04:20 PM
TH400 to Manual Transmission Swap msh227 General FSJ Tech 9 08-30-2009 09:47 PM
79 chief Transmission swap nlrwrangler General FSJ Discussion 4 03-17-2008 07:39 AM
