The next modification I would like to make on my 1984 Jeep Grand Wagoneer is the rhino grille conversion as stated in the title. I have read a lot of the forums on how to do this and I want to clearly lay out what needs to be done here and I invite advice from other members of the forum to help me make a complete guide to the conversion. Also, I have not seen anyone post they have done this successfully on a 1984 Grand Wagoneer, so if someone could tell me if that has been done for my particular model, I would greatly appreciate it.
What I think I know must be done-
1. Remove old grille, headlights, headlight buckets.
2. Reposition transmission cooler by mounting it on the inside of the brackets towards the radiator for clearance of the lower profile rhino grille.
3. Cut off mounting brackets for stock grille, of which there are five- One in the center below the transmission cooler, where you leave the tab that is already behind it. Two are parallel with the top of the turn signal lights underneath the circle cutouts. Two are right above the outside corners of the turn signal lights. (Here I have a question- Do you have to fill in the screw holes where the stock grille mounts underneath the hood, and do you have to take off the extra inch plate that is bolted on the top there across the middle?)
4. Make mounting tabs to be able to use the old CJ headlights and buckets in the wagoneer holes, or combine the back of your original bucket to the front of a CJ bucket as shown by David London on youtube. (Here I have another question- Has anyone upgraded to LED circle lights that could fit in those holes and if so do you have to rewire everything or is it fairly easy to convert?)
5. Fix and repaint the body to make it look presentable for where the stock grille covered the front and where the brackets were removed.
6. Fasten the new lights using the tabs you made for them or the modified buckets.
7. Fasten the rhino grille using the pre-existing tabs- of which there are five- The one in the center from behind the mounting bracket previously cut off, and two on each side of the center cutout. (Here I have another question- does it line up perfectly to the pre-existing tabs or do new holes need to be made to fasten the grille as well?)
Please fill me in on any steps that may be missing or details that I have explained incorrectly. Also, please answer the questions I incorporated into my steps. This way I can take pictures as I carry out this project and can make one complete start-to-finish outline of how to convert a grand wagoneer to the rhino grille set up.
Thanks in advance.
-Rob
70s Style Custom Paint Job
Rebuilt AMC 360 V8 Engine
Edelbrock 4-Barrel Carburetor, Air Cleaner, and Intake Manifold
Super Flowmaster 44 Exhaust with dual-to-single catalytic converter
Thanks in advance.
-Rob
