Old 02-11-2019, 10:53 AM
bumper mounts cut off
I have 1976 honcho
it has a wench bumper
wanted to put a regular FSJ bumper on
not the 3 piece factory type for 76
but the later one piece style
but when I looked at mount area
it appears the previous owner cut off the portion of the frame that extends beyond spring mounts.... where the 3 hole brackets usually go.
do you guys think a factory one piece can still be attached ? or am I stuck with the wench bumper ?
I guess someone with welding and fab experience could still make it work,...
did not know if anyone else has ran into this.
I know it would be better with photos
but I have still not figured that out.
1976 HONCHO Fleetside
Old 02-11-2019, 02:32 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
As far as I know, the pre-1980 frames didn't have the horns off the front, they were flat from the factory. To use a later bumper, you'll need to create those mounts yourself.
aa
Anthony
Old 02-11-2019, 02:40 PM
10-4
was beginning to think there was a difference
never really liked the 3 piece bumper
but would use one if I had to.
thanx for the information
kinda glad there is a chance nothing has been hacked off !
You shouldn't be bumping wenches with your truck anyway.
Old 02-11-2019, 02:51 PM
Cecil14's Avatar
I really don't think it'd be that difficult to make brackets to use the later style bumpers. You could probably even grab a piece of "C" channel the right dimensions and use that and the factory holes on the frame.
aa
Anthony
Old 02-11-2019, 03:13 PM
80Limited 80Limited is offline
If it is that pressing I have a junk chassis that I’m going to scrap anyway. It has good bumper mounts that could be cut off.
Old 02-16-2019, 01:52 PM
aa
Not hard at all. Take a picture to a fab shop and they could set you up for [likely] $100 or less.
Old 02-16-2019, 07:42 PM
10-4 thanx
80 limited is getting some for me.
if it fails
your ideas are good ones.
Old 02-17-2019, 06:41 AM
Perhaps he has a "winch" that lifts the "wench" up high where she would be out of danger. Still that's no way to treat a woman even if she is a "wench"
Resistance is not futile yet.
Old 02-17-2019, 02:10 PM
just saw this !!!
I got a dang good belly laugh !!!
out loud !!!
at my own ignorance too,.....
thanx for the good laugh
even it if was a thinly disguised shot , ha ha ha,,,,...its all good..
dave in nc
Old 02-19-2019, 10:08 AM
Originally Posted by SOLSAKS
just saw this !!!
out loud !!!
dave in nc
I can't hardly blame you. You surly heard or read others use it wrongly. It's a surprisingly common mistake.
I got a deal on the PTO winch set-up for my J20 because of this. The seller described it as a wench and the add didn't get the exposure it deserved.
After repeated corrections for the last twenty years my friend still calls a winch a wench.
Old 02-19-2019, 01:41 PM
another laugh.
thanx
sometimes the help I get here is not just for jeeps...
sometimes it is mental therapy in the form of a laugh.
I will surely spell something else wrong real soon.
Old 02-21-2019, 12:23 PM
When I swapped the chassis under my Cherokee (79) I cut the bumper brackets off and welded them to the front of the chassis (78). All those brackets are is C-Channel with some holes in it. I wouldn't bother buying donor brackets because they would be so easy for you to make. If you have a welder, drill and something to cut metal with (grinder, jigsaw, etc) you could make these in less than 30 minutes.
These are my 79 brackets welded to my 78 frame. The only holes "needed" and the 3 outer ones. I am not sure what the one on the bottom or the one in the middle are there for.
Old 02-21-2019, 03:06 PM
I agree rang
if the cut off pieces I am getting
have too much corrosion
or if I dont/can't use for any other reason
the C channel is a good idea
thanx
dave
Warn classic winch bumper ?s jepj2000 General FSJ Tech 6 01-08-2012 02:33 PM
bumper mounts toolthrower General FSJ Tech 2 04-22-2010 07:12 AM
Oh no... Its the ARB style winch bumper question again N2Jeeps General FSJ Tech 3 10-13-2007 12:42 PM
Pre 73' bumper mounts compaired to post 74' TEX General FSJ Tech 7 01-13-2003 04:19 AM
