trying to troubleshoot 84 grand wagoneer no start issue
using a test light with the key in the ON position
NO power at blue wire at the ignition switch
NO power blue wire at the solenoid end
power at light green wire going to module
power at red wire solenoid end
coil has power both - and +
plug wire coming out of coil has spark
if i bypass solenoid and put power to starter it works
wont start in neutral
no spark with screwdriver across solenoid (brand new just purchased )
replacing new solenoid from last fall
when probing with test light under dash in the switch at right hand side of steering column ( black wire) horn will sound?
also small round metal cylinder near fuse box( has 2? wires plugged into it) feels hot
any ideas??
tyh - =
any ideas??
tyh - =
