I set my timing today at idle and got it dialed in great pulls 21 in of vac at idle, BUT if I hold the engine at a steady rpm above about 1500 rpm it studders and sputters. then if I adjust the timing to run good above idle it runs like crap at idle and pulls like 15 in of vac. what do i do? i have the vac advance hooked up to the spark port of the carb with no CTO hooked up. should i hook it up to manifold vac and set the timing at idle so that when the engine is above ilde it retards the timing?
another thing. with the timing adjusted where it is running good at idle i checked the timing with a light and its way off the scale.
