  #81
Old 09-15-2010, 10:38 AM
gotmike's Avatar
gotmike gotmike is offline
wanted to show my LED light install as well...
first i drilled three holes in the taillight housing with the biggest hole saw that would fit...
then i used some cardboard to make a pattern for the plate that would replace my taillight lense... and cut the plate to fit...
then i painted up the plate... bolted it in place... and installed the lenses and grommets...
just running lights
brake lights
still visable clearly from an angle as well...
J.E.E.P
Just Everyone Elses Parts!
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Dana 70-HD Rear axle
Build thread: http://www.ifsja.org/forums/vb/showthread.php?t=90702
trailer build thread: http://www.ifsja.org/forums/vb/showthread.php?p=1314880&posted=1#post1314880
Old 09-15-2010, 11:04 AM
gotmike's Avatar
and i got some help installing my back seat finally...
fits like a glove... and it can adjust forward if need be...
it does sit a bit higher... but I can sit back there comfortably...
i'm still not sure exactly what it came out of... i believe it's a ford expedition back seat... but with the quick release still under it it was way too high... so i bolted it directly to the floor instead w/ a 3/16" thick plate...
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 09-15-2010, 01:45 PM
jeepjseries's Avatar
jeepjseries jeepjseries is offline
Looks great there, only wish i could install a Cummins in my Cherokee.
Old 09-30-2010, 11:51 PM
gotmike's Avatar
http://www.youtube.com/watch?v=aTHa4OOeKRY
just a video from the other weekend...
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 05-27-2012, 03:24 PM
gotmike's Avatar
here are some newer pic's
installed a winch in the front bumper...
cleaned up and re-supported the front clip first... when i cut out for my radiator i was running really short on time so i hand plaz'd it out and weakend the structure a bit... so i reinforced the bottom edge with some rectangular tubing to give it all a bit more rigidity...
then i welded in a piece of 3/8" plate between the bumper mounting channels to give me a good solid piece to mount the winch to..
back together waiting for another day to install the winch
winch all mounted up... wasn't much to it... drill four holes and bolt it down... going to build my own fairlead setup... the one that came with it seemed a bit narrow for the size of the drum on the winch...
she looks good on there...
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 05-28-2012, 08:30 AM
Resbum's Avatar
Resbum Resbum is offline
Nice rig. Thanks for updating the thread.
Originally Posted by Resbum
"What year is my truck?... Which part?" Build thread- http://www.fsjnetwork.com/forum/view...p=18290#p18290
Old 07-07-2012, 11:48 PM
gotmike's Avatar
Since i went hunting last year and brought back pictures, my wife wants to come with this year... so we bought a camper...
$500... it needs some work... but it was well worth the money... it's a '82 30' camper that sleep's 7... i get some real funny looks passing people pulling hills... lol...
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 07-09-2012, 08:34 AM
Resbum's Avatar
Niiiiiiiice!!!!!
Old 02-11-2013, 07:15 AM
Iceman0502's Avatar
Iceman0502 Iceman0502 is offline
Originally Posted by gotmike
to fit the heater element in behind the turbo downpipe i had to modify the stock housing and put the heater core directly against the firewall... then i used some galvanized sheet metal and made a new cover to direct the air from the factory fan, through the core, and then into the factory heater ducting...
Mike, Can you post a picture of your modified heater box? I was thinking of doing something similar by making a box that houses the stock heater core and a heater valve in the hose. The box will always flow air through the heater core and I was thinking that the heater valve would control the temperature by reducing the amount of water going to the heater core. I'm not sure this will work, but looking for ideas other than buying a underdash heater.
Thanks
1982 Wagoneer - 12V Cummins - In Progress
