  #41
Old 02-16-2009, 07:25 PM
Eugene 1's Avatar
Eugene 1 Eugene 1 is offline
Originally Posted by gotmike
i fabricated my own... i used 3" channel and notched a 90 out and folded it over to make an L then i bolted it to the frame and welded it as well... i cut a hole in the short section at the proper distance away from the frame and used the dodge body mounts since they fit into a hole and have a puck under them... bolt them to the body first then use jacks under the body seam to lift/level the body compared to the frame and make sure it has the proper clearance all along the frame once it's set tack it into place then try and drill a hole through an already present hole in the frame and through the new body mount... bolt it in place and then stitch weld it one inch top and bottom of each side... this will allow for some flex without breaking and the bolt will hold it to the frame relieving some of the stress on the welds... on the back i just used an existing hole that lined up with a cross body brace and put a bolt straight through with a hockey puck in between...
What about A Ramcharger frame? aren't they close to FSJ size?
JEEP
2005 Ram 1500 HemI
Old 11-05-2009, 06:35 AM
j2sax's Avatar
j2sax j2sax is offline
Mileage with 6BT frame/spring issues
Well, it looks like this may be the route I am taking if I score a 90 model Dodge I have my eyes on.
For those of you that have gone with the 6BT, what has your fuel mileage been like? Is there anything you wish you had done differently?
How's the stock FSJ frame holding up?
You noted that there was some spring sag, but there were no updates after that. HOw has that worked for you? I have set of Rusty's 4" on the J20 this will be going in... is that enough to deal with the oil pan clearance issues?
I am sure I will read over this and other links numerous times!
Have a great week,
Jesse
Jesse- Sparta, MO (Near SPfdl MO) J20 4 Door Project, Wag w/ 6" Rusty's, 33x12.5's, 360/727 (for now!), 77 J10, 80 J20, 3 80's Wags, 73 Commando, Lots of AMC Eagles, FSJ parts Rigs and parts
Old 11-05-2009, 09:06 AM
jeepmj_tj's Avatar
jeepmj_tj jeepmj_tj is offline
i'm getting 20-22 mpg out of mine empty. thats even around town. worst tank empty has been 19. towing my jeep in the mountains its been getting 15-16.
i am using stock 8400 lb j20 springs SOA. they have sagged some but the ride is real nice with the weight of the motor. i'm running 315's on h2's could probably clear 37's on the road.
one thing i need to do is try and fit a front sway bar back on. the stock one hits the oil pan pretty bad. possibility that I can make some drop brackets for it and get it to clear the pan if it doesnt then interfere with steering box.
01 TJ-Trail rig
91 MJ-Play toy and work horse
79 J20 Tow Rig- Cummins 6 cyl, DD since 07
Old 11-05-2009, 09:42 AM
rustywagoneers_com's Avatar
rustywagoneers_com rustywagoneers_com is offline
What radiator in yours Jeep MJ/TJ?
OP cherokee appears to have stock FSJ radiator....
There is no way to rule innocent men.
The only power government has is the power to crack down on criminals.
Well, when there aren't enough criminals, one makes them.
One declares so many things to be a crime that it becomes impossible for men to live without breaking laws.
Old 11-05-2009, 10:32 AM
J10Mike's Avatar
J10Mike J10Mike is offline
Delightfully Incompetent
Wow...Cool old thread. I forgot about this one.
These CTDs don't run very hot. A stock FSJ V8 radiator should work. I'm not sure about a stock I6 radiator though.
In my RC 4bt conversion, I'm keeping the stock radiator. Also, chances are that you will need a piece of cardboard in front of the radiator during the Winter. I have to do that in my 01 CTD Ram to get some decent heat.
www.j10mike.com
Old 11-06-2009, 03:24 AM
j2sax's Avatar
90 12 Vlv 6BT
Since the 90 is an all mechanical setup, are there any wiring gremlins to worry about? I wouldn't think so, but I wanted to make sure. It seems that all required would be for the starter solenoid, maybe some changes in the Alternator wiring (90 was pre-ecu, if I am not mistaken) and... well, I can't think of anything else.
Sort of like swapping in an old points engine, I guess!
I find out tomorrow if I get the 90, so we will see! It has a 2WD non-O/D trans... I might even run that awhile until I can find an NV4500 setup.... or maybe a good O/D Auto trans... what should I watch for? I want to stay away from the Electronic setups.
Thanks and have a great weekend,
Jesse
Jesse
Old 11-06-2009, 08:42 AM
jeepmj_tj's Avatar
i'm using the stock V8 jeep radiator. I ran it for two years with out any fan what so ever. I am now running a 16" electric fan and it only comes on while towing in the summer heat when heavily loaded or if it sits and idles after running for more than 30 mins
Since I went with the nv4500 I bypassed all the computer stuff on my motor. Had to have the alternator converted over to be internally regulated. Basically two wires to get the engine to run, trigger wire for starter relay and the fuel shut off solenoid. Obviously this is more involved but you get the idea.
01 TJ-Trail rig
Old 11-06-2009, 09:09 AM
angus1 angus1 is offline
I'm glad someone dug this up, I am doing the same swap. This Monday I am picking up the FSJ for transplant. this jeep will sit on a 60/70 combo behind a g-360 manual trans,on 37's. The only thing with wiring you might have to worry about is the alt. in the first gen dodge trucks are externally regulated. You can use this regulator ( Napa Part # ECH-vr440) Its an old style ford regulator.
Old 05-22-2010, 04:15 PM
walker1271's Avatar
walker1271 walker1271 is offline
wow im exited
i m on my way out and havent had a chance to read all the comment.i finalllly have a source of info.i have 87 grand wagonner and swaping in 92 12 valve cummins from my rolled 2500 pu.
any help woul be great !!!!!1
is there a kit to do the swap?
does the cummins match up with the wagoneers tranny?
Old 05-22-2010, 05:27 PM
The PIG Smith's Avatar
King Browless
Welcome from Fort Wayne, Indiana
Bryan Smith
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 12-11-2010, 03:48 PM
Diesel YJ's Avatar
Diesel YJ Diesel YJ is offline
Well lets keep it going. I picked up a 89 6BT earlier this week and I will be putting it in my 83 Wagoneer Limited later. I want to use it as a tow rig and expeditionary vehicle in the future. For now its a tow rig and the 360 will have to do. I would like to sand blast the frame and paint everything like I did with my last project before I build it. I am thinking 1 ton axles to handle the stress. I have a set of 4'' skyjacker full spring lift for the Waggy before I found the motor. Will they handle the weight? I have 4.5'' Extreme duty 6 pack springs on my YJ with a turbo 6.2 and they are holding up just fine.
2000 WJ Grocery Getter and RC approved, 4'' Lift.
1983 Wagoneer Limted - Future tow rig
1988 Grand Wagoneer - All stock but super sexy and clean.
1989 6.2L Turbo diesel YJ, 6.5'' lift, 35's D44 F&R, SM465, NP205, Woody's shafts, Christmas tree air freshener.
Old 12-11-2010, 08:47 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
Question
I like the way this thread started, but its been rather sparce in info from the OP. Did he disappear somewhere?? I have some questions about real world operation and not many answers. I've commited myself to building a Cummins J-truck and thought I wanted to run the 5.9L, but at only 20-22 MPGs I'm beginning to re-think the 3.9L and the purported 30s MPGs.
Originally Posted by will e
Old 12-12-2010, 09:27 PM
Phillips889's Avatar
Phillips889 Phillips889 is offline
Pm him he gave me a lot of helpful info and pics for my swap
1981 j10 cummins diesel Daily driver UP AND RUNNING!
1979 J20 PARTING OUT SEE PARTS FORUM
1979 Cherokee widetrack up on blocks.
Old 12-13-2010, 01:13 AM
Tigger4X's Avatar
THANKS!!
Old 12-13-2010, 06:33 AM
Mikel's Avatar
Mikel Mikel is offline
Most people with full size trucks and 4BTs get low to mid 20's. 30MPG claims are either VERY rare or the fruit of bad math skills.
1969 M715 6x6
1963 J300 Swivel frame
Old 12-13-2010, 09:58 AM
Bill Moore's Avatar
Bill Moore Bill Moore is offline
nice swap, I am using my M715 4bt for my tow vehicle and it does not have the reserve power that I need. I am consdering dropping in a 6bt as it will primarily be for towing. The fit looks extremely tight, but has been done before as several have noted. Dont want to do it, but consider it a must for crosscountry towing, especially in mountainous areas where the reserve power is critical. I have not intercooled the truck and probably will not due to space limitations.
DDs
67 KJ715 4bt AA OD 465 np205
78 J20 Chevy 305 nv4500 np205
Projects
Sons Build 1980 short bed J10, j20 axles, 4bt, nv4500, np205, shortened M715 bed and fenders
Freedom is not Free, it is paid for with Blood
Old 12-13-2010, 09:59 AM
Bill Moore's Avatar
btw, if you drive it conservatively without load, Im see any where from 22 to 30 mpg. But I rarely get above 60 mph.
DDs
Projects
Old 12-13-2010, 11:05 AM
Mikel's Avatar
I think rarely going over 60MPH falls well outside the driving of the average person. My best tank was 25.2MPG driving through country roads in upstate NY with a complete 6BT in the bed. I can see getting 30 if I drive VERY conservatively (50-55 highway), but I rarely cruise under 70-75. Yes, I have a lead foot.
1969 M715 6x6
Old 12-13-2010, 11:08 AM
Mikel's Avatar
Bill,
What have you done to your 4BT? What are the specs? I would consider spending some time and a few $$ on that engine before pulling it. I believe a 4BT makes for a very balanced engine in a M715, in terms of weight, power, economy and durability. A 6BT kinda pushes the envelope a bit, but it all depends on what you want the vehicle to do.
Mikel
1969 M715 6x6
Old 12-13-2010, 12:51 PM
Bill Moore's Avatar
if mine had a jtruck cab, I probably would drive closer to 70, but the M715 Aerodynamics being quite a bit worse than the jtruck (hard to believe isnt it), you really dont want to drive it over 60.
DDs
Projects
