Old 08-25-2018, 12:33 PM
ls3waggy ls3waggy is offline
Vent window restoration doesn't seal
Hey guys, having an issue with one of my vent windows.
I bought a kit from BJ's to do both front vent windows, just about done with the first one (what a job) and upon installation I can see some light through the vent window seal around the pivot area.
2018-08-25_11-27-57 by Jimmy Casey Photography, on Flickr
2018-08-25_11-28-10 by Jimmy Casey Photography, on Flickr
My drivers side factory one which I haven't started on yet seals perfectly..
Any ideas what I should do here? Or what I did wrong?
Old 08-25-2018, 05:37 PM
Tripwire's Avatar
Tripwire Tripwire is offline
is it a hole or bunched up material? cant see it so good in the pic, it appears the window closed correctly?, you might try massaging it out/ stretching with some heat and use a wooden dowel to press the gasket tight into the corners - or buy some black silicone an put a dab in the hole?
It's just a grand ol time replacing that seal - right??? hey at least you had the guts to do it
trip
Abort? Retry? Ignore? >
Old 08-26-2018, 04:20 PM
trip
It just looks like there isn't enough material there to seal around the pivot point. The "hole" is just above the window in between the frame and the glass.
Yeah, it definitely sucks, I really just want it to work so I don't have to re do it haha
Old 08-27-2018, 11:15 PM
Old Ironsides's Avatar
Old Ironsides Old Ironsides is offline
Yeah I experienced the same thing when I did my Seals from BJs too. There is a 2" by 1/16" gap on both windows.
I was thinking of:
A) Going to a glass shop and seeing if they had a U shaped rubber gasket I can slip on the vent window to seal that gap,
Or
B) Getting a can of liquid plastic and making my own seal.
Haven't gotten around to it, I just turn the stereo up!
Grant
'76 J-10, 401 (1406/2131/DUI/RV Cam), TH400, Part Time, 3" lift, 33s, 346K Miles
'75 J-10, 360 (1406/2131/MSD), TH400 QT, 6" lift, 33s, 100K Miles
'77 Cherokee Chief, 401/Th400, QT, 4" lift... Totalled
Old 08-28-2018, 09:24 AM
I was thinking of:
Or
Going to attempt a liquid seal today.
Debating if I should leave the stock seal on the other side. Pretty disappointed in the aftermarket for these trucks lately haha
Old 08-28-2018, 01:26 PM
SJTD SJTD is offline
Could you post a picher of the new one you haven't installed with the one you removed?
Sic friatur crustulum
Old 08-30-2018, 01:04 PM
Think I figured out the issue.
Theres a sliver of weatherstrip that seems to be missing, not sure if it's a defect or not, definitely isn't something I cut off.
New one (passenger side)
2018-08-30_11-55-53 by Jimmy Casey Photography, on Flickr
Old (drivers side)
2018-08-30_12-00-59 by Jimmy Casey Photography, on Flickr
Comparing the two
2018-08-30_12-01-56 by Jimmy Casey Photography, on Flickr
I'm not pulling the passenger one back apart, I'm debating if I wanna leave the drivers side on as the heat shrunk the weatherstrip. But it still seals fine.
Old 08-30-2018, 03:56 PM
When using repop parts you have to have reasonable expectations or you're going to be disappointed. they're seldom perfect, often not much good, and sometimes total crap. considering the ultra-low volume they sell we're lucky they make anything.
that said the vent seals I installed from Bj's fit and seal great. but I have the older style pivot so maybe that fits better.
Old 08-30-2018, 11:17 PM
I understand some fitment issues, but not pieces missing. Especially for the almost 200 dollar price tag. Too much material makes sense, but not too little.
I can see there is an outline of a rubber piece thats supposed to be there but it isn't.
Old 08-31-2018, 07:38 PM
On '78 and older the pivot was altogether different. since mine fit fine I assume that's what they were made to fit. is it possible there is a pre and post 1978 seal option ?
Most likely they only make one and you just have to live with it but I'm not sure.
Vent window frame assembly removal caionneach General FSJ Discussion 10 09-06-2011 09:17 PM
Team Grand Wagoneer Vent window seal set. :( Kenall Customer Corner: (Vendor product discussions) 5 02-13-2011 03:42 PM
Vent Window Removal? jMedia General FSJ Discussion 4 07-09-2010 07:32 PM
Rear Main Seal....anything else besides this? Seemer General FSJ Discussion 18 04-25-2010 04:33 PM
Closed knuckle inner and outer oil seal replacement-write up KaiserMan Drivetrain 19 01-12-2007 08:04 AM
