Old 01-04-2018, 11:36 AM
ls3waggy ls3waggy is offline
Drivers window crooked?
Upon installing my driver's side window I noticed it was crooked. Everything is together and I can't really seem to make it straight again. Is the glass cut differently from side to side?
Old 01-08-2018, 06:02 PM
SJTD SJTD is offline
Is it perhaps turned around? Front edge at rear? Maybe caused by switching sides?
I think there's an inside/outside of the track the regulator pin goes through so if you swapped sides and used that for orientation you would get the front edge at the back. Whether that makes a difference I can't say.
Sic friatur crustulum
Old 01-09-2018, 09:39 AM
Door glass isn't side specific or directional.
Same glass for all 4 door windows.
1994 Caprice wagon
Funny Tailgate Window Story tmlint General FSJ Discussion 4 01-17-2011 02:22 PM
Drivers Window Regulator- 88 GW cfg7613 General FSJ Tech 8 11-10-2010 11:48 PM
Driver's side window gear track installation... Wagonaught General FSJ Tech 3 02-26-2006 05:57 AM
Rear Window Re-Engineering PhilSine General FSJ Tech 5 07-22-2002 03:47 PM
REAR WINDOW STUCK DOWN IN COLD WEATHER Thecozmobile General FSJ Tech 7 02-04-2002 04:09 AM
