Old 05-21-2011, 03:23 PM
Mavawreck Mavawreck is offline
Factory firewall to engine clearance on '88 wag?
Hey guys,
Swapped my valve covers today and noticed that the back of my valve covers are rubbing on the firewall. How much space is there usually? Looks like the cruiser control cable bracket is even a little bent from banging on the firewall. Motor mounts have been on my to-do list. Have the poly kit from BJ's sitting here. Looking underneath it, there are two sets of slots on the frame the mounts can bolt to, mine are bolted to the back slots on the drivers side and the forward slots on the passenger side. Is that correct or should they be in the forward holes on both sides? I'm guessing I need to loosen up the transmission before I try sliding anything forward? That might explain the clunk I get in reverse. If I'm lucky.
1988 Jeep Grand Wagoneer
http://www.ifsja.org/forums/vb/showthread.php?t=153928
1996 T100 SR5
Old 05-21-2011, 03:29 PM
I got the Willys....
My first FSJ was like that. Went to do a valve cover gasket set on it and couldn't get the passengers side off It was right on the heater box. Sounds like your motor mounts are bad. Mine where! Good time to do your tranny mount as well.
1971 Gladiator
Old 05-21-2011, 03:39 PM
I've got new transmission mounts as well and the radiator is already out. Any idea of how much clearance you have now? Or which holes were used on the frame?
1996 T100 SR5
Old 05-21-2011, 04:57 PM
serehill serehill is offline
Gone,Never Forgotten.
Mines like that.
I believe the P.O. put mine in wrong but would like to know for sure. He rebuilt mine. I had an 83 & it was factory & they were in the front.
Old 05-21-2011, 07:57 PM
Just checked my J20 with original mounts. Looks like around 3" on the left and 2" on the right.
1971 Gladiator
Old 05-21-2011, 08:23 PM
mark j's Avatar
mark j mark j is offline
I have poly mounts on my '89 with both sides to the front mounting position. The poly mounts are thicker than the old compressed rubber mounts and seem to elevate the engine and displace the rear of the passenger side valve cover closer to the firewall. I think I have about 1/2 inch clearance on the passenger side and 2" on the driver side- which is just enough to clear the kickdown brackets. Not sure how well you can see from these pics. Hope it helps.
72 wagoneer- My first FSJ
89 G-wag- built 401
09 Rubicon
Old 05-22-2011, 06:44 AM
Thanks Mark, that actually helps a lot. Looks like your kick down brackets rub in the same place mine do.
1996 T100 SR5
HDC CTO (???) Gil General FSJ Tech 46 03-31-2010 10:23 PM
Any suggestions while engine is out? Firewall Prep? 80wag General FSJ Tech 9 03-23-2008 05:37 AM
Engine Tuning Attempt JohnIL General FSJ Tech 11 09-10-2007 06:52 PM
New engine, old carb, hard starting JohnIL General FSJ Tech 0 07-27-2007 02:40 PM
Is my engine toast? Chero77 General FSJ Tech 8 12-04-2001 11:05 AM
