Almost ready for color, and hood vented
The Jeep is almost ready for final paint (no pics as yet). We've done two coats of primer with wet-sanding in between coats and after. So I guess this makes it three times I've sanded the entire vehicle.
The plan is to do all the painting and masking next Sunday (June 10 2012, for posterity's sake).
Per this thread, pics of the hood venting job...
Here's the expanded metal, with a scale for ... scale.
My "test hood", before mods:
Piece of expanded metal lying on the hood for marking the cutout. Note: the second time around I made a template out of cardboard (recommended!).
I started the cutout 8 inches forward of the rear of the hood to clear the inner portion of the hood. I put the bottom of the cutout 5/16" up from the fillet of the bend to center the cutout in the section. Of course this depends on how tall you make your cutout.
Welded and ground smooth:
Now, some things learned by doing a "test" job:
1. Make a template for the cutout. That way you'll get a smoother more symmetrical (between sides) cutout.
2. Tack the expanded metal onto the hood, then use JB Weld or some other industrial epoxy product to hold it on. It's not a structural member! JB Weld is good because you can use it to fill cracks, and it's grindable/sandable.
3. It's easier to grind the expanded metal smooth before you weld it onto the hood!
Here's the final product:
A view I hope to see soon:
