Old 10-22-2010, 12:08 PM
thomastenn thomastenn is offline
ideas of a build thoughts desired.
ok i have a ideal of a build let me know what you guys think and have any tips or other thoughts. i have a perfect 1990 gw frame thinking of putting a j-truck cab on it with a custom built rock crawler bed i already have a built ls 5.3 for it and a th400 and np241 case thinking of some custom m715 fenders for the front and 6" springs to clear about 46" tires and run some 2.5 ton rockwells or i already have a rear d70 hd then i just need i d60 front it would have plenty lift i think with the springs and the axle over with the rockwells. and ofcourse the rear shackle stuff from bjs for the extra 5-6". any thoughts or ideas?
looking to initiate project j715
Old 10-22-2010, 01:51 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
IF you go with the rockwells you have to make sure of the driveline angle and the pinion whacking the oil pan ... basically a lot of clearance issues. You can use the search feature on here and get some good tech info on how to do it right.
Originally Posted by will e
Old 10-22-2010, 03:04 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
Dont mount that cab until you have the suspension figured out. You will probably have to move the front axle forward and the engine/cab back to fit the rock.
Probably need to plan to move the radiator to the bed too.
You dont need a SOA + 6" springs to clear 46"s with 715 fenders.
What kind of springs do you plan to use? Ya might want to consider links instead.
Also, Tad makes a quality product (rear shackle flip), but I wouldnt count on it to hold 46"s on rockwells without both serious frame and bracket mods.
Other than that, go for it.
Old 10-22-2010, 05:21 PM
Michael's Avatar
Michael Michael is offline
I think this needs to stop here. I do not want to shut down a good build thread. Pms sent.
1994 YJ
Amc 360
TF727
Stak 3 speed
44" Pitbull Rockers on Trailworthy H1's
Rockwells
76' Wagoneer
401....new project
Tow Rig Daily Driver// 2007 6.7 CTD Dually
Old 10-22-2010, 06:32 PM
Dmntxn77's Avatar
Hey watch this...
Dont forget about steering too. Once you move your axle forward far enough, you will either have to get real creative with linkage or you will have to go full hydro...
Old 10-22-2010, 06:54 PM
Chief Gunner's Avatar
Chief Gunner Chief Gunner is offline
I am thinking 46's on 2.5 rocks, fully hydro would probibly be the best way to go.
The War Wagon: 1986 GW- SOA/SF on 33X12.50's, 360/727/NP228, CS 144 Alt, OBA
Wife's DD: 2012 Ford Focus SEL
My carbon foot print is bigger than your's.
WWW.SOCALULTIMATE4X4.COM
Old 10-22-2010, 08:27 PM
Michael's Avatar
Now i think 6" springs are way overkill. If it is a "truggy" I think flat fenders front or no fenders just my thought. I would stick it on Rancho 44044's or Alcans...2" at the most keep it low! Full Hydro, and I would cut the firewall and move the engine back since you want to keep the body. Just to start anyway.
1994 YJ
Amc 360
TF727
Stak 3 speed
Rockwells
76' Wagoneer
401....new project
Old 10-23-2010, 06:30 AM
think im goin with the 60 and 70 and stick to 42s i have used rockwells before on a ramcharger i built and i know all abut the monster chunks and they are as heavy as a buolder lol
Old 10-25-2010, 03:57 AM
jeeping1974's Avatar
60/70 built with 42s-46s, full hydro, Alcan 1" springs in the front, 4-link the rear, flat belly, cage it and get rid of the 241. Go with a D300 or 205 or 203/205 setup. Push the rear axle back some and center the drivetrain so that your front and rear driveshafts are equal length.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
74 j10 build up jeeping1974 Off-Road FSJ Tech 232 05-12-2009 07:59 AM
AMC 304 V8 Stroker Build - 327 V8 ! Greg Taylor General FSJ Tech 5 02-14-2008 06:55 AM
NEWBIE BUILD UP DARWIN General FSJ Discussion 42 04-24-2007 11:42 PM
Engine Build Thoughts Needed Millerluck General FSJ Tech 24 11-23-2003 12:52 PM
