I started collecting parts for a tbi swap on a 401 and decided that the larger one from a 454 would be the best fit. As I'm going through the different guides though, I'm starting to see that the parts list doesn't quite match what I'm finding on the truck. Right now it looks like my donor truck has no Esc module or knock sensor. My question is... Do I just keep trucking on? I mean, if there is no sensor and no wiring for it, is it safe to assume that as long as I use the original ecm and wiring harness that it'll still work? Should I graft a harness from a 350 instead? I'm starting to see now that many of the 454s didn't come with these, so I was curious if any of you have already dealt with this before?
The donor truck is a '93 3500, with a 4l80 I believe, if that makes any difference
