Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Homegrown Vendors: (Members who produce FSJ related items)
  #41
Old 05-01-2010, 02:27 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Just added the '55-'57 Chevy hydroboost I've put together... it's on the first post in this thread.
More stuff coming folks Currently working on a ZJ setup....
Old 06-18-2010, 04:50 PM
Elliott's Avatar
Cowboy Up
The Jeep ZJ hydroboost mount is completed.
Old 07-30-2010, 09:01 PM
Elliott's Avatar
Cowboy Up
btt
Old 08-10-2010, 05:29 PM
The Colonel's Avatar
Originally Posted by Elliott
If you are building custom hoses using JIC 90* swivel fittings and need to know the part numbers for the respective AN-6 port adapters here they are:
Steering box pressure out, 11/16x18 flare: Aeroquip # FMB2965
Steering box pressure out, 18x1.5mm: Aeroquip # FMB2609
Pump pressure out, 5/8x18 flare: Aeroquip # FMB2964
Pump pressure out, 16x1.5mm: Aeroquip # FMB2608
HB pressure in, 18x1.5mm: Aeroquip # FMB2609
HB pressure out, 16x1.5mm: Aeroquip # FMB2608
Hello, the Aeroquip part numbers actually all start with FBM, not FMB.
Thanks.
Old 08-10-2010, 05:54 PM
Elliott's Avatar
Cowboy Up
dyslexia... got it, Thanks
Old 08-25-2010, 09:11 AM
bigblock91
Posts: n/a
Hey Elliot do you know if The GM hoses will work with a ford style ps pump?
Old 08-25-2010, 10:07 AM
Elliott's Avatar
Cowboy Up
They won't, requires adapting and I'm not entirely sure there is a straight adapter made to go from either 3/8 flare or metric oring to the style Ford uses... don't recall the name of the fitting but can look it up tonight. You may need to cut the Ford hard line and adapt/splice... unless you use Ford F250/350/550 hoses that will attach to the Ford hard lines at the HB... I probably have a set of those and they are metric oring at the HB end. You might also be able to source those at Autozone or the dealer but I'm pretty sure I have at least one set.
Old 08-25-2010, 10:26 AM
bigblock91
Posts: n/a
Ok a little lost with all that. I need a set of hoses off a f250 / 350 /550 with hydrobost.. Those will bolt to the pump. And HB with out any adaptation? Did I read that right? Would it be easier to have the hoses made? Thanks in advance.. I need ps Li es to run my motor.. I'm close to a street test and I'm getting antsy
Old 08-25-2010, 10:30 AM
Elliott's Avatar
Cowboy Up
I think that will do it for you if you just get the full lines. Then may end up long. Pressure from the pump goes to the larger 18mm port on the accumulator side of the HB and pressure out from the smaller 16mm HB port goes to the pressure in on the steering box.
Old 08-25-2010, 10:32 AM
Elliott's Avatar
Cowboy Up
If you can, you may want to grab the pressure valve and spring out of a Ford HB pump too, it may give you more line pressure over a non HB pump's valve. Haven't really sorted the Ford stuff out yet but I did pulll a valve to mess with and compare.
Old 08-25-2010, 06:05 PM
Elliott's Avatar
Cowboy Up
Here's the hard line from the HB to the Ford pump line: (threads will have teflon tape at the ends only, on the center section of hard line, not the HB end)
Here is the valve from the Ford pump showing the cut off section of the hardline to the HB:
Old 08-29-2010, 11:21 AM
Can I run a PS cooler with this?
Certainly, make sure it is installed down line from the T-fitting in the return line if a T-fitting is used.
So you mean between the T fitting and the reservoir, in the return line, is this correct?
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 p/u
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 08-29-2010, 11:30 AM
Elliott's Avatar
Cowboy Up
If you have a single pump system, not the dual pump set up, you want to locate the cooler in the return line after it comes out of the steering box and before the Tee fitting the HB feeds into which is in line to the pump/reservoir.
Old 08-29-2010, 06:25 PM
Gotcha.
Thank you.
51 Willys p/u
'74 CJ5
'75 J-20 Wrecker
'75 J-20 p/u
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 09-03-2010, 05:36 AM
Here is my HB install, thanks for all your help Elliott!
http://home.comcast.net/~amc_jeep/Hydroboost.htm
Old 09-03-2010, 08:00 AM
srobertsfsj's Avatar
srobertsfsj srobertsfsj is offline
Finally finished my install last night. Rebuilt the MC and bleed the brakes. Couldn't believe how nasty the old fluid was in the master cylinder, looked like used engine oil. Took it for a test drive and I can't believe what a difference, like night and day! I can stop on a dime even with 35" tires. Thanks Elliot!
Scott R.
'86 Grand Wagoneer Super Chief 360 / TBI / WT conversion / 35x12.5x16 BFG Mud-Terrains (Project Link)
Old 09-06-2010, 11:48 AM
herm herm is offline
i have a 1972 wagoneer with all stock vacuum breaks. I would love to get one of your bolt in solutions for HB. I am guessing the astro unit with the correct bracket would be the way to go. would i need to replace the MC? i see that you spec down to 74 but not to 72. thanks.
72' Wagoneer
Old 09-06-2010, 12:53 PM
Elliott's Avatar
Cowboy Up
You should be able to keep the stock MC since it's a vacuum MC meaning it will have a shallow dimple in the piston where the booster rod engages. I may have firewall mount already made so if you check your brake pedal let me know if the rod is on driver's (most likely) or passenger side of the pedal.
Old 09-09-2010, 12:48 PM
the stock pump should be good too right? the pump is not too old and works good. the shaft in on the drivers side. thanks.
72' Wagoneer
Old 09-09-2010, 03:03 PM
Elliott's Avatar
Cowboy Up
In most cases the 1300 psi pumps are adequate. You can always increase the performance if you think it is neccessary be 1) brazing a second return nipple onto your reservoir and elimiate the Tee fitting in the return line for the hydroboost, 2) replace your pressure relief valve with one from a 1500psi pump out of hydroboosted pre '80 chevy truck. You pedal will take the position #2 mount that I have in stock. I'll shoot you a PM with my address for paypal if paypal works for you.
Thanks,
Elliott
