Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Homegrown Vendors: (Members who produce FSJ related items)
  #221
Old 02-19-2017, 09:48 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
For the two bronze rod end bushings you might need when using an Astro hydroboost you can order them from McMaster-Carr:
https://www.mcmaster.com/#standard-s...rings/=16f9pna
9/16" OD x 1/2" 6381K607 $5.42
5/8" OD x 1/2" 6381K611 $5.33
Old 02-21-2017, 08:56 AM
chrism chrism is offline
Hi Elliot,
I scanned through the thread but didn't see an answer to this. I'm having no luck finding any of the van (astro or P30) units in the junkyards. I do see some on early-mid 2000's chevy trucks. Are these usable before I attempt to extract one?
My cherokee is a 79. I am planning on using a disc 14bolt from one of these trucks so I might be able to use the master too.
1979 Cherokee
1979 CJ-7
Old 03-04-2017, 07:05 AM
Elliott's Avatar
Cowboy Up
You can use just about any hydroboost but as far as fitting it to the vehicle you have to figure how to adapt the brake rod to your pedal and then adapt the mount to your booster block while giving you the correct rod distance and angle so it doesn't bind on pedal articulation. The early Astro is the only HB that is going to match up using a 1" spacer and it's the only one I sell a spacer to adapt.
Old 03-06-2017, 07:18 AM
Thanks for the reply. I ended up scoring a 95 astro unit on ebay. I'm going to do the adjustable push rod instead of the spacer.
1979 Cherokee
1979 CJ-7
