Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Homegrown Vendors: (Members who produce FSJ related items)
  #201
Old 10-08-2013, 03:37 PM
camduke22's Avatar
camduke22 camduke22 is offline
Noob!
Hydro-boost me
Hey Elliot, I messaged you awhile ago but never got a response. I am looking for a entire bargain set up for my 1974 j10. Help? disc front, drum back. mostly new lines
Old 10-08-2013, 03:43 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Hi, yeah... sent one right away but the board may not have gotten it to you so emails still work best but here you go:
Cheapest way.... As long as you rig uses an aluminum booster block at the firewall.... Is to get a '95 Astro van HB that has the spade shape brake rod end with the 5/8" hole and bush it down to 7/16" the get a $25 1" steel spacer from me so it gives it the correct rod length and bolt it up. Replace the studs in the HB mounting plate with 1 1/2" 3/8-24 bolts.
Thanks,
Elliott
Old 10-08-2013, 03:52 PM
camduke22's Avatar
Noob!
Yeah i responded email on the 14th but never got a response. Any way i have the aluminum spacer right now, can i get the 95 astro HB unit and spacer from you? just to make sure i get the right one.
Old 10-08-2013, 05:19 PM
Elliott's Avatar
Cowboy Up
I don't have any used ones for sale, just doing new stuff but if you happen to get one with the round end and 1/2" hole by mistake you just have to drill it to 9/16 before you bush it down to 7/16 so it's not a huge deal.
You can paypal $25 to me at sterlingworth16 at yahoo dot com and I will weld up the spacer for you when you are ready. It's bare so it will need to be etched/primed/painted.
Couldn't find your message for what ever reason so please folks, don't try and message through the forum, just email me at sterlingworth16 at yahoo dot com
Thanks,
Elliott
Old 10-08-2013, 06:26 PM
camduke22's Avatar
Noob!
Payment sent, i still might need some help once i find a booster.
Old 10-29-2013, 10:42 AM
ThisGuyUKnow's Avatar
Elliot, sent you an email with a hydro question. Your PM box was full
'85 CJ7 Laredo- Rebuilt 360, Tuned Port Injection, T-176, D300, W/T 3.31 w/Trac Loc, 31x10.5x15 BFGs
Old 10-29-2013, 12:07 PM
camduke22's Avatar
Noob!
He is real quick to respond to his email, sterlingworth16 @ yahoo dot com. Obvi take the "dot" out and put a real one.
Old 01-22-2014, 08:46 PM
Elliott's Avatar
Cowboy Up
Yes I am
Old 05-05-2014, 01:49 PM
Elliott's Avatar
Cowboy Up
Bump, new stuff listed on ebay....
For whatever reason... I can't edit the first page of this thread but you can open any of the links at ebay and check out my current listings like this new one for the new custom hydroboost sockets: http://www.ebay.com/itm/Custom-Hydro...item43c6447204
Those sockets work really sweet as you don't have to remove the rod end or clevis end to fit the socket over the rod and these will fit any hydroboost mounts out there that I know of.
Also, check out the 90* master cylinder rotator/adapter I designed for tight fit situations where you clock the hydroboost for more engine clearance or want to fit a different master cylinder. This will work on any hydroboost made: http://www.ebay.com/itm/Hydroboost-9...item43c93e772e
Thanks folks!
Old 05-05-2014, 03:45 PM
autogatto's Avatar
autogatto autogatto is offline
Elliot I'm trying to send you a private message but your account cannot accept anymore incoming messages..
1977 CJ 5 401cid, 1979 CJ 5 343cid, 1979 cj 5 304cid, 1976 CJ 7 304cid, 1981 J 10 360cid
Old 05-05-2014, 03:50 PM
Elliott's Avatar
Cowboy Up
Yeah... don't do that Shoot me an email through the forum or to sterlingworth16 at yahoo dot com
Old 09-21-2014, 08:39 PM
Zorm's Avatar
Zorm Zorm is offline
shot ya an email
83 Cherokee 4dr WT(axles)
4" Rusty's lift, 32x11.50s,
4.6 stroker modified 4.0 MPFI engine
still hunting a Triumph TR6
2007 SeaRay 205
71 F-250 Camper Special
HE guides my path, forgives me when I stray and lights my life.
Old 10-27-2014, 08:37 PM
Crossfit_Wagon Crossfit_Wagon is offline
Noob!
Need a system
Hey Elliott,
I live in Fort Worth so it's nice to see a fellow Texan on here. I am new to the FSJ world but love my 84GW. I am wanting to install a hydroboost system and wanted to reach out to you for what a system would cost me? I tried to PM you but your mailbox was full. Man in demand!
Thanks,
Robbie
Old 11-18-2014, 11:48 AM
Flingarrows's Avatar
Flingarrows Flingarrows is offline
Hi Elliott,
Ive got your HB kit on my M715 just as steering now. What pressure hose would I need to go from the HB to a 78 FSJ power steering gear? Im finally adding Power Steering
Thanks
Old 08-05-2015, 11:17 AM
Kaiser's Avatar
Kaiser Kaiser is offline
checking for pulse
Hey Elliott-
Shot you an email last week! You still alive?
1965 Kaiser/Jeep Gladiator J300 7600 GVW
Old 08-17-2015, 08:45 AM
Zorm's Avatar
Looking to see if you have a set up or the spacer for a 82 CJ7
2007 SeaRay 205
Old 09-09-2015, 01:46 PM
stinkbomb1020's Avatar
stinkbomb1020 stinkbomb1020 is offline
Noob!
Looks like his last post was last year. I hope he is ok.
'72 J4000
Old 10-23-2015, 01:28 PM
http://www.ebay.com/usr/sterlingwort...p2047675.l2559
Old 10-24-2015, 09:51 AM
Elliott's Avatar
Cowboy Up
Heya, I'm around. Just took a break to move and try and get a new shop built. Haven't broken ground on the shop but it should start soon. Please hold your requests for the time being and I will probably be moving most of my listings to www.custompowerbrake.com so when you see that site revised for a sales point then you know at what level I'm back to work at getting these out to you.
Don't figure I'm just sleeping in the meantime I have some new stuff coming out, some is ready already and some is waiting to be tested. There is nothing else like what I'm going to offer anywhere in the market so for the hardcore crowd.... you will like it My hydraulic consultant is so confident in the design he wants me to patent it so.... will see how it goes on my truck and then letcha know.
Old 02-18-2017, 10:56 AM
Elliott's Avatar
Cowboy Up
The shop is built and I've been back at it. Pretty busy cranking out different versions of hydroboost applications so I don't have a lot of time to be answering questions on Tech that you can find the answers to here on this thread.
For probably the best hose kit for the cost get with PSC Motorsports. #HK2040 will cover rigs that are '80+ and if your's is earlier then you want another hose kit where you can add two of the SAE flare AN fittings and two of the metric o-ring fittings.
Yes, I can still sell you a 1" welded steel spacer for using an astro van hydroboost. $30 shipped and it's unpainted.
I'm not stocking/selling bushings for the rod ends since the last time I asked Purvis they wanted me to buy 100..... you can probably find them on ebay. The HB from the '95-95 Van with ABS had a spade shaped rod end with a 5/8" hole that you can bush straight to 7/16". Earlier Astro units or those in '94-95 without ABS had a round shape rod end with a 1/2" hole and you will need to drill/ream that up to 9/16" before you can bush it down to 1/2". There may be some nylon bushings, like off a ZJ that might work and save you the trouble but you will need to look around and see what you can come up with.
If you want a new hydroboost from me that's a direct bolt in they are currently $446. shipped. Add $200 if you want me to supply a hose kit but I prefer not to mess with them when you can get them cheaper at PSC
'81+ FSJ will need an MC that fits the hydroboost, the '93 C3500 with DRW fits that bill but you can go aftermarket too.
1 1/8" - 1 1/4" bore will be your best bet in most situations. If you run the latest largest dual piston axles/brakes then get year specific (to your axles) MC from a chevy truck that had hydroboost.
To contact me send an email through here, not a PM. You can also reach me through www.custompowerbrake.com
Thanks all
