Old 06-03-2019, 02:35 PM
cma's Avatar
cma cma is offline
Brake System
Guys, changed some weeks ago front Disc Brake Rotors, Calipers, and of course all Bearings and Gaskets in the Axle.
Rear side does have 2 year old Brake Cylinders.
after some Miles driving, and using the Brake, i feel a warm Rim and the Rotor is warm too. So i think there is something with the Piston in the Caliper. Could it be that the System does not have enough Power to push the Piston back?
Calipers are RMFG.
Thanks for your inputs! Markus
Markus!
Picture story:
Old 06-03-2019, 04:18 PM
PlasticBoob's Avatar
All Makes Combined
No idea, but most reman calipers are garbage. When I did the Tundra brake upgrade on my 4Runner last year, I went through three different remanufactured calipers from two different parts stores before I got one that didn't leak in various spots (fittings or bore).
Though I can't explain why the entire Autozone brake system on my Cherokee is still leak-free and performing flawlessly 17 years later... I guess standards have really slipped lately.
Rob
Click for video
Old 06-03-2019, 06:57 PM
they are supposed to be warm and driving, really hot is an issue though.
Old 06-04-2019, 11:21 AM
Mass's Avatar
Mass Mass is offline
Are we talking fresh dinner roll warm? That's normal.
It just depends on the driving style. I've done enough tires to know sometimes you have to wear work gloves because heavy vehicles or "spirited" drivers will have hot rims and lugs.
If you drive easy and use the brakes sparingly like letting the vehicle naturally slow down before braking you should only feel a warm rim. If you drive like everyone else on the road they will be hot.
Jack up the entire front or back and spin the wheels by hand. It should definitely make it a turn or 2 when you give it a good spin.
If they stop as soon as you let go then you definitely have an issue. Could be dragging brakes or over tightened bearing.
89' GW 6BT Cummins
To change A/C refrigerant or no...(R134a & Freeze 12 ?) caionneach General FSJ Tech 16 07-23-2010 10:29 AM
Brake's won't work Help Thumperbr549honcho General FSJ Tech 5 05-03-2009 08:19 AM
ignition switch brake warning light issue HELP!!!! westcoastflea General FSJ Tech 36 11-29-2006 11:01 AM
Axle swap and brake system idoc General FSJ Tech 8 10-14-2003 10:47 PM
Help please Dan G General FSJ Tech 36 09-02-2002 08:47 AM
