Old 08-30-2016, 07:11 PM
I got the Willys....
Buying a J3000.....DRW
Just agreed to buy this 1968 J3000 dually. It's a factory 161" wheel base Buick 350/T18 rig. It's rough. Really could use a cab, but the frame looks good other than typical surface rust and some light pitting. The odometer shows 24K. Pretty sure this used to be a chassis mount camper.
Truck is pretty unique. The frame rails are one stamping, it hasn't been spliced together. The flat section of the frame has been reinforced (looks factory), It has a two piece rear driveshaft and is very well optioned.
It's a Custom Cab, has a large back window, PS (pump isn't on right now), PB, bucket seats, tinted glass, Lock-O-Matic hubs and transfer case mounted parking brake.
Motor is supposed to be rebuilt and runs great. Aftermarket 4bbl intake and carb, stainless (according to the owner) headers.
It runs, drives and stops. Worst part is that a couple of the wheels are rotted.
Note the plate on the left side of the frame behind the cab. Owner says it's only on that side and the frame is rock solid behind it. No clue why it's there.
1971 Gladiator
Old 08-30-2016, 08:17 PM
jpcoutts's Avatar
jpcoutts jpcoutts is offline
Congrats on a great find! Welcome to the dually club! More pics please. I might have a line on a wheel if you can't find one.
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Old 08-30-2016, 08:25 PM
I'll snap a bunch when I'm up there (it's a 7 hour round trip for me) this weekend.
Looks nicer in the pics, but what doesn't right?
I think it needs ALL the rear wheels. At least the inners. That's going to be rough! I'll shoot you a PM if I can't end up getting some. I was thinking of getting an 8 lug wheel redrilled.
1971 Gladiator
Old 08-30-2016, 08:50 PM
jpcoutts's Avatar
I hope at least some of the wheels are good. They are so hard to find. I also thought about having some other wheels re-drilled but no one could(or would) do the coining needed to get the proper lock between the wheels after mounting. Coining is the raised ridge around every other bolt hole with a depression around the other holes that makes them fit together as a unit when mounted for strength I suppose.
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Old 08-31-2016, 04:40 AM
Could always use a pin in one and a hole in the other to lock them together like Ford (I think it's Ford) does.
Does yours have left and right hand threads on the wheel studs?
1971 Gladiator
Old 08-31-2016, 06:06 AM
mud89's Avatar
mud89 mud89 is offline
I am envious, congrats for this new one
As i wrote when i saw the post of the previous owner on fsjnetwork, it's one of the very last dually from the factory : one can deduce from some service bulletins from the sixties with serial numbers that only a few dozen duallies were produced in Toledo with the Buick engine and it's one of them ! Moreover this example is very well optioned according to your description and the pics.
By the way i thought that the rigs with an extended frame were special orders with the specific plate below the VIN plate, it seems that this one does'nt have the plate, maybe an aftermarket extension when converted to a chassis mounted camper ?
If you change the cab, please keep the emblems, doors panels and these great bucket seats to stay stock.
Old 08-31-2016, 06:41 AM
mud89's Avatar
Some serial numbers :
Service Bulletin 918 (04/19/68) : 300 014
Parts Bulletin D315 (08/19/68) : 300 027
Service Bulletin 942 (10/04/68) : 300 026
Service Bulletin 954 (02/05/69) : 300 026
Service Bulletin 963 (03/11/69) : 300 027
It seems that the higher serial number for these duallies with the buick engine is around 300 030, so around 30 built in Toledo, all in 1968
Edited : BTW around 190 duallies (J3000s) were built with the 327 for the three years : 65, 66, 67
Old 08-31-2016, 10:36 AM
Do you have a link to the tread on FSJN? The guy I'm buying it from didn't say anything about being a member, and he bought it from an old timer that I doubt goes on line.
It's not a aftermarket extension from what I can see. The main frame rails are all one stamping from front to back on it. I haven't seen it in person yet.
1971 Gladiator
Old 08-31-2016, 02:16 PM
mud89's Avatar
Link below
http://www.fsjnetwork.com/forum/view...hp?f=7&t=10943
I guess that he registered on fsjnetwork just for the sale
Old 08-31-2016, 02:29 PM
I'm not over on FSJN much, I missed that. I found it on Craigslist.
He seems like a decent guy. He's going to use the money toward buying a J10 like his father had that's for sale locally to him.
1971 Gladiator
Old 08-31-2016, 10:58 PM
mud89's Avatar
ok good news, He'll probably stay on FSJN if he buys a J10
The rig is also on jeeptruck.com
Old 09-01-2016, 10:21 AM
My machinist friend said it shouldn't be a problem drilling 8 lug wheels to 6. And I've got 6 free Ford wheels sitting on a dually at work that's heading to the scrap yard soon.
I'm not sure how necessary the coining is. GM dually wheels don't have anything locking them together. Ford seems to have a pin.
1971 Gladiator
Old 09-01-2016, 12:33 PM
Nice Thomas. Amazingly clean for an east coast rig.
Old 09-01-2016, 05:49 PM
It gets less solid the closer you get Joe. It really does need a cab.
I did well with wheels today. A customer of ours has a 65 F350 dually that's been sitting for a while. He's going to let me take the outer rear wheels, then swap my bad wheels for his good ones. He only cares that he has four tires on his at the end of the day.
Two of his are single piece rims.
1971 Gladiator
Old 09-01-2016, 07:21 PM
jpcoutts's Avatar
Great find on the F350 wheels! Do they have the coined holes? I think most duallys of that era had them. The studs on my truck are all right hand threads. As for the single piece rims, I've only seen pictures!
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Old 09-01-2016, 07:26 PM
Great find on the F350 wheels! The studs on my truck are all right hand threads.
Good to know! My 63 has L and R, didn't want to accidentally snap any on the 68.
He also has a 66 F350 with 17.5" 6 lug wheels. Be a pain to find tires for though! Best part is, his 65's wheels look exactly like the Jeep dually wheels. Same pattern/size holes stamped in them. He has 6 on the truck and one spare.
1971 Gladiator
Old 09-01-2016, 07:28 PM
jpcoutts's Avatar
Jackpot!
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Old 09-01-2016, 07:35 PM
trellis8's Avatar
trellis8 trellis8 is offline
Ristows' Minion
Sweet!
Old 09-03-2016, 07:41 PM
Just got back from looking at it. Contrary to what the PO said it's a stretch job. Stretched 34 inches. The frame was cut right at the bend where the frame flares out behind the cab. Very professional looking job though. The lower reinforcement starts about 20" ahead of the splice, and ends about 20" past it. It's been stretched a long time. The patina is exactly the same as the rest of the frame.
Might be factory? If Jeep was putting out stretched wheel base rigs it doesn't seem like it would have been worth making the tooling for longer frame rails with such low production.
Motor runs good. It's got an aluminum intake and a Weber carb. Clutch (supposedly new) feels good. Genuinely looks like a 24K mile truck. There is no wear on the pedal or steering wheel, and the shift pattern is still barely visible on the knob.
It needs all 6 wheels
The cab is savable, but will need a lot of work. It still has the trim/paint tag. I'll post that up when I get the truck home. Seems like it's an original Polar white truck. The rear diff has a posi in it. Still has the tag.
I got it for $2500.
1971 Gladiator
Old 09-04-2016, 03:01 AM
Mikel's Avatar
Mikel Mikel is offline
Making such large stamping dies is insanely expensive. I can't imagine Jeep doing that in order to build a handful of vehicles.
1969 M715 6x6
1963 J300 Swivel frame
will j4000 styleside bed fit j3000 truck fully standard jeep General FSJ Discussion 2 04-23-2015 07:37 PM
Looking at a 66 J3000 FrankenNova General FSJ Discussion 9 03-16-2012 10:02 PM
What To Look For When Buying A Grand Waggy? ILikeMud General FSJ Discussion 10 01-05-2011 02:01 PM
J3000 Sighting in South Bend, Indiana (NOW WITH PICS!) The PIG Smith General FSJ Discussion 13 10-10-2008 08:40 AM
might be buying a '65 J3000 vacca rabite General FSJ Tech 17 02-27-2007 10:15 AM
