Old 06-28-2014, 04:25 PM
Rich88's Avatar
Rich88 Rich88 is offline
Double flare tool a joke
I'm replacing brake lines, and had to transfer the 9/16" flare nuts to the new lines at the MC and proportioning valve. I decided to try doing things right and use a double flare tool.
After dozens of attempts following directions as well as my own experimentation I simply could not get the intended result. Each and every time I did step one, I ended up with distorted oblonged inverted crimp instead of a nice even round one. So I was compelled to go back to the scary practice of using a single flare....which has worked well in the past. But still....
So what's the secret with double flaring?
Old 06-28-2014, 05:49 PM
Chumley360 Chumley360 is offline
Patience, swearing, and practice. Also those ones with the double wing bolt jaws don't hold the line worth a darn. I've got a Snap-On one that probably does the best out of all the ones of that style I've used/had. Now I've got one of the fancy Mastercool hydraulic ones at work and it's awesome. But it's not worth the price for the casual user.
1968 M715-Driveway queen/in progress
Old 06-28-2014, 05:59 PM
ProTouring442's Avatar
Is it one of the ones in a little red box? If so, they suck.
Mastercool makes a good manual tool, part number 70092. You can find them on Ebay or other tool sales sites. I've had good luck with ToolDiscounter.com, and they have them for $45.
Old 06-28-2014, 06:12 PM
Yes.
Supposedly the Rigid tool works well for a non-hydraulic tool.
http://www.amazon.com/Ridgid-23337-3.../dp/B001HWKZLO
You can also try using Nicopp/Cunifer line, which is softer and seems to flare more easily.
I've had good luck with the inline tool now supplied by Cal-Van, but it only works with 3/16" tubing http://www.cal-vantools.com/p-162-au...ring-tool.aspx
Old 06-28-2014, 07:43 PM
Originally Posted by tgreese
Yes.
That one by Ridgid looks very nice. I think I'll have to pick one up.
Old 06-29-2014, 09:00 AM
serehill serehill is offline
Gone,Never Forgotten.
YUP
The rigid works well still need a little patience though.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 06-29-2014, 12:04 PM
243 243 is offline
I recently bought the HF kit in the red box, had to do flares for my fuel lines, I didn't follow the directions and extend the tube through the clamp the required distance and I cut that on off and one flare was slightly oval.
There may be better tools but it worked fine fore me.
Making consistent bends in multiple parallel lines is a lot harder than good flares, I bet the electricians can bend brake and fuel lines a lot better than most.
David
76 NT Cherokee
83 CJ7
05 Frontier CC 4x2
Old 06-29-2014, 01:14 PM
bufurd's Avatar
bufurd bufurd is offline
Helps to spray a little WD40 or some kind of lube on it too...
Current fleet
07 JK Wife bought new...
Old 06-29-2014, 11:10 PM
The cheapies use to say "mount in a vise for best results". I think the one I have still does.
Window Wipe Molding Remover Tool. Worth it? temps425 General FSJ Discussion 6 08-09-2011 06:53 AM
fuel line flare Luntec General FSJ Tech 9 06-17-2008 01:48 AM
single vs. double flare shackwrrr General FSJ Tech 9 06-22-2006 09:38 PM
Brake Hard Line Double Flare Fittings viscacha General FSJ Tech 0 04-19-2005 06:58 AM
Clutch Alignment tool same as Clutch pilot tool? mtnbikerman General FSJ Tech 2 02-11-2005 12:08 AM
