Old 01-19-2013, 03:38 PM
meanphil's Avatar
meanphil meanphil is offline
Ls conversion fuel delivery....74 Wag
Havent been on here for quite awhile...Ive since put a 5.3 out of a 2004 Avalanche in my 74 Wagoneer. Taken out the side saddle fuel tank opting for a rear mounted tank. Problem is that I don't know what tank actually fits back there nicely. In a perfect world I would like to be able to run a GM in tank fuel sending unit, but thats going to mean the tank probably hanging down further than i would like. Just wondering if anyone new of another setup? Maybe Cherokee rear mounted tank? Or am I going to be stuck with an externally mounted regulator? Any help would be appreciated
Old 01-20-2013, 08:13 AM
rawdave's Avatar
rawdave rawdave is offline
I put in a mid 80's bronco fuel tank. Requires a body lift (3") for it to fit well.
"You fancy people with your shoes."
87 Grand Wagoneer
2009 GMC 5.3L Vortec
Sterling 10.25 Rear
8 Lug J10 Front
TSM Mfg Rear Disk Brake Conversion
33 Gallon Rear Poly Tank
69 J-3000 Pickup
Plans:
2.8 Cummins Diesel Repower
6L90
Atlas Transfer Case
Old 01-20-2013, 08:23 AM
okjeep okjeep is offline
Regardless of the tank you use, it will be doubtful you would get to run the stock pump assembly.
On my wifesyj I have run a variety of pumps but found this pump to be the best to feed the 5.3ho for psi and volume:
2007 jeep grand Cherokee
Delphi dfp fe0417
48 gph/58psi
It is purchased as the pump only. You can not get a late model pump only. It is the entire assembly.
I am looking at getting a 30 gallon tank from Tahoe to mount at the back. The dimensions work well for a truck. Will have to fab up mounts no matter what.
Old 01-27-2013, 09:08 AM
meanphil's Avatar
Thanks for the input...Ive mocked up the Tahoe tank with a cardboard box made from the dimensions and that does seem to be a good fit.
Old 01-27-2013, 06:22 PM
ingersoll113 ingersoll113 is offline
Rear Mount Tank
I put one in my 86 Waggy out of a cherokee and used a steel gas tank skid out of a late 80's cherokee (Newer ones are plastic). I welded 1/2" flange nuts in the frame, made my own straps and installed it using an inline pump feeding a Vortec 454. It tucks up nicely and looks factory. Sorry, it is in storage or I'd get you pics. Very happy with it.
Some guys say to keep the stock Cherokee pump in place as a booster for a higher pressure inline pump.
Vapor Lock?!? 88sunroof General FSJ Tech 2 08-02-2008 06:07 PM
Gas mileage improvements.. skunked General FSJ Discussion 34 08-24-2007 01:21 PM
How many miles should it go? 82Laredo General FSJ Tech 9 01-20-2007 10:23 AM
Discovery - cat doesn't taste like chicken 3jeepsdeep General FSJ Tech 13 10-19-2004 01:52 AM
