Old 07-07-2011, 06:38 PM
xuno_gil's Avatar
xuno_gil xuno_gil is offline
Replacing stock distributor with HEI distributor
Ok so I’m getting ready to do this and I just want to make you I have the steps down, so here is what I got…
  • Take #1 spark plug out and cover hole with finger, start turning the engine CW until you start feeling pressure build up in the hole.
  • Then find the timing marker on the pulley and continue turning the engine until the timing mark lines up with the Zero marker on the engine
The engine should now be at top dead center with the #1 cylinder
  • Look for the metal ridge on the shaft on the HEI distributor and line the mark with dimple on the gear. This should be setting the distributor to the #1 setting
  • insert the distributor into the block with the ridge facing forward
  • Rotate the rotor slightly CCW to help it sit onto the cam this should be only slight rotations if it sits in slightly but not all the way in rotate the engine slightly CW to make it sit just right.
  • Once the distributor has been seated rotate the engine back CCW to line the timing marker back up to the Zero marker.
  • Tighten distributor onto the block.
Ok so do I have everything right? Am I missing anything?
Now I’m thinking ahead, once the distributor is on, I hopefully have marked my #1 port and then the order should be the same so I should be able to just attach the wires to the new distributor of off the #1 port right?
Alright well let me know if this is right and if it is, hopefully it helps someone else too even though I’m sure this subject has be covered already J
I just want to make sure I got it, thanks
Old 07-07-2011, 06:50 PM
newtojeeps's Avatar
I didn't go through all that I just looked to see where the rotor was pointing and put the new distributor in with the rotor pointing the same way. I put the gear off my old dist. before I stabbed it in there and then put on the wires. It fired right up and I had to move it 2degrees.
Old 07-07-2011, 07:16 PM
xuno_gil's Avatar
Hmm yea I was assuming that as long as you could place the rotor, then why not just put the new one in with the rotor facing the same way. I guess starting from scratch with out the old rotor to go by would lead us to these steps.
Now is the hooking up self explanatory? I got the hooking up to a 12V keyed slot but the hooking it up to the distributor, is that self explanatory? Is it just a straight one wire pinch connecting thing?
Old 07-07-2011, 07:25 PM
What year is your truck? Never mind - I found it ... it's a '76.
Old 07-07-2011, 09:43 PM
FallonJeeper's Avatar
FallonJeeper FallonJeeper is offline
Just note two positions on the rotor.
1. Where the rotor points with the distributor all the way in
2. Where the rotor points with the distributor all the way out
The rotor will rotate as you pull it out. When you put the new distributor in, start with the rotor pointed toward position number 2. The rotor will rotate as you push it in to fully seated, and should line up with position 1.
It might take a couple attempts to get it perfect, but patience will reward you. Good luck, if you do it once, you'll be an expert.
Old 07-07-2011, 10:22 PM
xuno_gil's Avatar
got it thanks alot, I'm also going to be replacing the valve cover gaskets on it. I picked a set up, should I use them or just silicone sealant or a combination? I've heard of some people saying you should use some RTV on the cover with the gasket.
Any special recommendations?
Old 07-07-2011, 10:29 PM
austinaubinoe's Avatar
Mine were leaking pretty bad when I bought mine. The PO had squeezed alot of RTV in there and it looked like it had melted or just could not handle the oil. Installed some Fel Pro 'Perma dry' gaskets that I got on RockAuto for $10. Best valve cover gasket I have ever used! So much better then cork. Been on there dry for about 2 months with zero oil leaking.
Used the same type of gasket on my trans pan, that worked great too.
If you already bough cork, Ive had good luck treating cork/ paper gaskets with this:
http://shop.advanceautoparts.com/web...7CGRP2132_____
But really just buy the rubber ones!
Old 07-07-2011, 10:38 PM
xuno_gil's Avatar
Nice, thanks yea I picked up the fel pro rubber gaskets just wanted to make sure that just a strait installation with no added stuff was the best way to do it, Thanks again
distributor woes flatlander58 General FSJ Tech 7 08-20-2007 05:34 AM
D.I.Y Throttle body injection write up (With pics!!!!) and this is no hoax Wagoneerlover Engine 28 06-25-2007 12:43 PM
Is stock 89 distributor vacuum advance adjustable ? GED General FSJ Tech 2 01-09-2005 12:48 PM
Wire hot to touch JAllenWAG General FSJ Tech 16 11-27-2003 01:52 AM
Distributor gear--Help Help L.D. General FSJ Tech 6 09-01-2003 04:43 AM
