I have a CustomEFIS multiport setup in my truck with a dodge dakota T Body and I am having trouble with surging idle and poor starting. It used to start without touching the throttle at all and now I have to crack the throttle to get it to start and then give it a little throttle to continue running until it warms up or else it will stall. Once it does warm up the idle wanders and in general is to high. I should mention that I have a vacuum leak some where in that i only have about 15 pounds of vacuumn with a steady needle. I changed the intake gasket and checked all the vacuum lines and I dont have a break booster so I running out of places to look for the intake leak. I have already tried a new AIC valve and I changing out the tbody next week just to see what that does. Any other ideas as what is wrong?
CUSTOMEFIS Multiport Idle issues
I can't help you with your issue at the moment other than guessing it's probably the vacuum leak, oxygen sensor, or TPS, but may I ask you to please edit your title and put "CustomEFIS MPFI" in it? It'll make it easier for people to spot if they're just browsing through the forum pages looking for interesting threads in a few months.
Are you capable of datalogging? If so, can you post logs showing startup and idle?
Need more info
If it ran fine at one time then the vacuum leak is the most probable cause.
What if anything has been done since the problem started? Do you have any pictures of the system installed? Try the old propane bottle and hose trick to try to locate the vacuum leak source( do this in a well ventilated area and use caution to avoid any open flames or ignition sources) . The high idle is a classic vacuum leak symptom. Is this a speed density or MAF system?
Something simple like a hose to the MAP sensor may have been accidentally pulled off or developed a crack if this is a SD system.Seek out the authority to share his knowledge, be enlightened and fix it right the first time.
Originally posted by PlasticBoobI can't help you with your issue at the moment other than guessing it's probably the vacuum leak, oxygen sensor, or TPS, but may I ask you to please edit your title and put "CustomEFIS MPFI" in it? It'll make it easier for people to spot if they're just browsing through the forum pages looking for interesting threads in a few months.
Are you capable of datalogging? If so, can you post logs showing startup and idle?82 J10 SOA 6" SPRINGS D60-D70 W/DETROIT LOCKERS 38x15.5 TSL'S on 12" M/T CLASSICS 460 V-8 C-6 CUSTOM EFIS EFI AND HYDROBOOST
Originally posted by Dr.EIf it ran fine at one time then the vacuum leak is the most probable cause.
Something simple like a hose to the MAP sensor may have been accidentally pulled off or developed a crack if this is a SD system.82 J10 SOA 6" SPRINGS D60-D70 W/DETROIT LOCKERS 38x15.5 TSL'S on 12" M/T CLASSICS 460 V-8 C-6 CUSTOM EFIS EFI AND HYDROBOOST
If you can save it as a text file or a CSV (Comma Separated Value) file.Ethan Brady
www.bigscaryjeep.com
Originally posted by djmacI use Data Master to record logs. It uses .uni files which this site does appear to accept. Is there a work around?
Sounds like others have had problems with this company.
Join the Surf East community for expert guides on top surf spots, in-depth gear reviews, professional surfing lessons, and vibrant surfer gatherings. Whether you're a seasoned surfer or just starting out, Surf East is your premier destination for all things surfing. Dive into the adventure today!
What ECM is used,ie. 1227730? What mask, ie. $8D? Describe the procedure you used to adjust the throttle plates and the IAC when you installed the new one? Do you have a DVOM? Have you checked the TPS? What are the IAC step counts that the datalog show at idle in gear? I know its a lot of questions, but it is hard to diagnose with out knowing as much info as possible.Seek out the authority to share his knowledge, be enlightened and fix it right the first time.
Where do I find the ECM number? I know the ECM is from a 91 corvette. I have a flash burner so in the past I have recorded a data log and emailed it to the tuner.
What is a DVOM?
I have replace the AIC and TPS. I set the TPS to .56
Throttle settings: First I warmed the engine up then I disconnected the IAC. I reduced the rpm via the throttle plate screw to the lowest possible setting without stalling. Then i reconnected the IAC. Then I set the TPS to .56.
I will take a closer look at the IAC settings but I noticed after the idle settles down that the IAC is at 0 and so is the TPS Position? Does this sound right? One thing that has changed in the past is that in order to start the motor i have to give it some gas. It used to start just like factory efi just turn the key and go. Any suggestions on this symptom?82 J10 SOA 6" SPRINGS D60-D70 W/DETROIT LOCKERS 38x15.5 TSL'S on 12" M/T CLASSICS 460 V-8 C-6 CUSTOM EFIS EFI AND HYDROBOOST
DVOM is Digital Voltage Ohm Meter.Ethan Brady
Originally posted by FSJ GuyDVOM is Digital Voltage Ohm Meter.82 J10 SOA 6" SPRINGS D60-D70 W/DETROIT LOCKERS 38x15.5 TSL'S on 12" M/T CLASSICS 460 V-8 C-6 CUSTOM EFIS EFI AND HYDROBOOST
Originally posted by djmacYes, I call it a multimeter. I have read where some have recommended keeping The iac counts at 40 and the Tps at 1;5% @ warm idle? How do you manipulate the settings to achieve that?
The TPS should be set for whatever your system calls for. TBI systems want to see about 0.57 volts (IIRC) for a closed throttle position.
I don't know how your throttle plates are adjusted, but I suspect there's a screw adjustment somewhere on the throttle body.Ethan Brady
.57 is what I recall setting it to in the past. What I am unclearon is what a good starting point for t plate opening? That maybe why I have to push the pedal a littleto get it to start? Or maybe the iac is at the wrong position at the time of start?82 J10 SOA 6" SPRINGS D60-D70 W/DETROIT LOCKERS 38x15.5 TSL'S on 12" M/T CLASSICS 460 V-8 C-6 CUSTOM EFIS EFI AND HYDROBOOST
This link shows what ECM you might have. Scroll down to the bottom.
Look over @ the Third Gen forums and see if you can finds ome tech info about what your throttle plates and IAC should be set at.Ethan Brady
