Old 03-19-2010, 05:48 AM
Frank Black Frank Black is offline
J4006019 AMC grommet for the PCV availability?
I'm changing over to the 3731 Edelbrock intake - tried ordering the AMC grommet for the PCV valve and Mopar informed me that the part is no longer available. Does anyone know where I can get one? Thanks.
Old 03-19-2010, 05:55 AM
HELP section @ a parts store...
Old 03-19-2010, 11:51 AM
ya sure
Old 03-19-2010, 12:00 PM
rawdave's Avatar
rawdave rawdave is offline
Try D&L 4WD (770) 567-1229 if they don't have it I can just about guarantee they can get it.
"You fancy people with your shoes."
87 Grand Wagoneer
2009 GMC 5.3L Vortec
Sterling 10.25 Rear
8 Lug J10 Front
TSM Mfg Rear Disk Brake Conversion
33 Gallon Rear Poly Tank
69 J-3000 Pickup
Plans:
2.8 Cummins Diesel Repower
6L90
Atlas Transfer Case
Old 03-19-2010, 12:05 PM
Go to the www.dormanproducts.com web site and enter PCV grommet. There are about 100 different grommets there - there's no listing for the specific grommet, but I expect someone has used one of the available grommets for this application.
Dorman makes the HELP products.
Old 03-19-2010, 12:07 PM
Originally Posted by Frank Black
ya sure
Then I guess I'll keep the part number for it to myself.
Old 03-19-2010, 12:57 PM
azpackrat's Avatar
azpackrat azpackrat is offline
I think the poster may not be familiar with the HELP products and thought you were making a joke. I have heard that the Chrysler big blocks used the same grommets, Edelbrock also has them.
Old 03-19-2010, 01:14 PM
Knuck's Avatar
Knuck Knuck is offline
If all else fails.....there is fleabay.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230345737319&ssPageNam e=STRK:MEWAX:IT
81 J20 "Mater", 401/T-18/NP208, Rhino Conversion, 4" Rusty's all-spring lift, extended length front shackles, 2" rear blocks. LT285/70r-16 M.T. Baja Claws, Front Locker, Custom Rear Bumper, Custom Front Bumper under construction.
Status: Up and running
Old 03-19-2010, 01:45 PM
TPICherokee's Avatar
I have HELP number 42060, I believe this is the correct one.
PVC Grommet for Edelbrock manifold SnowShoe General FSJ Tech 13 02-27-2010 02:50 PM
PCV Grommet RAMBLINFSJ General FSJ Tech 14 02-23-2007 05:21 PM
89 4.0 breather hose grommet? Arborigine General FSJ Tech 5 09-02-2006 12:32 AM
