Old 06-29-2014, 05:56 PM
vickmorrow64 vickmorrow64 is offline
87 Jeep Grand Wagoneer Oil Pump rebuild
Hello I am new to forum. Own two of these beauties, but neither are on the road yet. Has anyone done an Oil Pump rebuild? I had a mechanic check oil pressure and there is none - luckily FSJ has not been driven. He had to remove the alternator to get to the port on the block. Any tips/steps are appreciated. I ordered the oil pump rebuild kit form autozone today.
Old 06-29-2014, 11:12 PM
Midplate kit from Bulltear (also sold at http://BJsoffroad.com )
Old 06-30-2014, 05:21 AM
Strode's Avatar
Strode Strode is offline
1st Chair, Cowbell
Here's a couple I have bookmarked, the 1st one from Ristow here.
http://www.ifsja.org/forums/vb/showthread.php?t=106458
http://www.jeepforum.com/forum/f8/am...hread-1050446/
Ristow's Bunker
Old 07-01-2014, 03:40 PM
Strode - thx for the links - takes the guesswork out of it
Old 07-01-2014, 05:58 PM
Rich88's Avatar
Rich88 Rich88 is offline
What's interesting is info that's missing. Does the engine start and run at all?
A few things:
Your mechanic may never have seen a 360 before. Oil pressure is best checked at the oil pressure sensor port, and certainly does not require removal of the alternator. Otherwise, any competent mechanic would have been able to figure it out. You're paying for work he need not have done.
Another clue to no or very low pressure is if upon start-up you hear horrendous clacking from hydraulic lifters not being pumped up. Is such a noise present?
If you mean no oil pressure as in NO oil pressure (as in zero), if the oil pump is turning at all, it's a near impossiblility. More likely that the gearing between the driven oil pump shaft (Also connected to the distributor) is stripped. But then it wouldn't start either.
Its possible the over pressure bypass valve is stuck open, or its regulating spring broke. That could cause no oil pressure. But that's unlikely. If you do the OP overhaul, you'll still have no pressure.
Anyway, it can never hurt to get an OP overhaul kit, since if it doesn't need one now, it eventually will anyway. But I'd not bother unless I knew for sure there's really NO oil pressure, because likely there's something else going on.
Electric Fuel Pump Installation w/ relay leostevo General FSJ Tech 0 03-21-2011 06:07 PM
jeep overheating wont run 2 hours from home HELP!!!! westcoastflea General FSJ Tech 14 08-02-2008 02:26 PM
327 Fuel Pump Rebuild 70sWagoneers General FSJ Tech 2 11-13-2006 07:02 AM
So what if the oil pump rebuild isn't the solution? stuart General FSJ Tech 5 11-27-2000 03:34 PM
